Re: Hood hinge ID ?
[Re: sixpackbee]
#1680063
09/29/14 11:47 PM
09/29/14 11:47 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
I now have seven 71-2 B's and all have the hinge on the left. Have had several other 71-2 B's with the same hinge. I need to check all my 73-4 B's and see when they changed to the one on the right. I think sometime mid 73.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: Hood hinge ID ?
[Re: moparmarks]
#1680064
09/30/14 12:25 PM
09/30/14 12:25 PM
moparmarks
Ok I was laying in bed last night thinking about this as something did not seem right in my head. So I checked my cars this morning and man was I wrong.
All my 71-2 B's including my 71 RR built 10/70 have the one on the right with teeth. All my 72's have teeth. All my 73-4 B's including an early built 73 have the one on the left without teeth. I should sleep better tonight.
Re: Hood hinge ID ?
[Re: moparmarks]
#1680065
10/01/14 02:21 PM
10/01/14 02:21 PM
Posts: 2,304 WI
RestoRick
WI
Correct.. one other thing you'll find is that sometime in '72 (late I believe), they started using the base part that has slot cutouts. The base with slot cutouts are used on the '73-74 style hinges.
Re: Hood hinge ID ?
[Re: moparmarks]
#1680066
10/02/14 11:06 AM
10/02/14 11:06 AM
Posts: 3,060 Western New York
sixpackbee
Western New York
Thanks, Mark & Rick. Mark, I did not intend for you to loose sleep over this but I appreciate it. Other than correctness does one hinge any advantage over the other?
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
Re: Hood hinge ID ?
[Re: sixpackbee]
#1680067
10/02/14 11:16 AM
10/02/14 11:16 AM
moparmarks
Loosing sleep is my fault. Not sure if one is better than the other. Rick may know. Do know that there are different springs though. Charger and Plymouth Air Grabber hoods take a heaver spring than Plymouth non-a/g hoods..
Re: Hood hinge ID ?
[Re: sixpackbee]
#1680068
10/02/14 02:06 PM
10/02/14 02:06 PM
Posts: 2,304 WI
RestoRick
WI
'71-72 vs.'73-74 type- The '73-74 design have a longer service life. The '71-72 get sloppy sooner from the teeth wearing. Both will get pin wear too, of course.
