Re: Heater blowing cold. '98 Jeep GC.
[Re: moretoys]
#1680041
09/30/14 10:50 AM
09/30/14 10:50 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
I'm a little confused here. Two posts. One telling me that if the heater hoses are both hot, the core is restricted. The other is telling me that if one is hot, and the other cooler, the core is restricted. I don't think it can be both ways. The hoses are both hot after running for a while (long enough to get the thermostat (195) to open). As I said above, I can get a little heat to come out the defrost vent after the Jeep is warmed up. But as soon as I turn on the fan, it cools down rapidly and stays cold. I think I'm leaning towards the blend door being the problem. Just wondering if anyone has gone through this recently? I'm I on the right track? I watched a few vids on You Tube, put out be "Heater Treater". Looks like I'm in for a little heater box surgery!
[Re: bigblock340power]
#1680042
09/30/14 11:20 AM
09/30/14 11:20 AM
Posts: 178 Tidewater, VA
TMCCuda
Tidewater, VA
I had a similar problem on my 2000 Cherokee. I believe my problem was air trapped in the heater core. I drained and refilled the system, but it wouldn't blow hot.
The small underhood space for the radiator and hoses leads to air being trapped in the system. Factory probably should have installed an air bleed near the thermostat.
1970 Plymouth Barracuda
1994 Ram 1500 4x4 5.2L
2004 Ram 1500 4x4 5.7L Quad Cab
[Re: TMCCuda]
#1680043
09/30/14 02:06 PM
09/30/14 02:06 PM
bigblock340power
Elk Grove, Calif.
Ya got me wondering with that one. I took the Jeep for it's oil change a few minutes ago. Again, as I got the thing up to temp, I tried the heater. It blew warn at the start, then went to cold fairly rapidly. On the way home I tried it again, pretty much the same thing (only I left it on low, and it almost stayed up with the demand). I sat in the car port with the heater on defrost (RPM around 2000+). On low (fan speed) heat will keep up, and stay somewhat warn. But as soon as I go to med./high back to getting cold (or drop my RPM). Perhaps an entire coolant flush should be done (using a good grade of flush chemical), getting ride of any possibility of trapped air, and some fresh coolant.
