70 Duster side moldings #1679972
09/29/14 04:26 PM
09/29/14 04:26 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Looking at a 70 Duster 340. It is coded with V8X for the rear tail light surround tape treatment. It has a V5X as well. How do the side moldings work on A-bodies? I only know E-bodies and they had a little stud coming off the body to hold a clip that held the molding. Is that what A-bodies used or did they use an adhesive side molding? There is no evidence of the studs on the side of the car but the build sheet says V5X. Thanks!
1970 Dodge Challenger T/A
Re: 70 Duster side moldings [Re: jeff968] #1679973
09/29/14 04:43 PM
09/29/14 04:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
VERY difficult to find. Originals Ive seen were all adhesive.
Re: 70 Duster side moldings [Re: ScottSmith_Harms] #1679974
09/29/14 04:54 PM
09/29/14 04:54 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Okay, so there is no problem that the little studs are not present. Thanks!
Re: 70 Duster side moldings [Re: jeff968] #1679975
09/29/14 05:18 PM
09/29/14 05:18 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
On '70 Mopars I think they were adhesive as Scott said(except Challengers?) and then in '71 they went to mounting studs.
Re: 70 Duster side moldings [Re: 44D6PAKCUDA] #1679976
09/29/14 06:43 PM
09/29/14 06:43 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Nope, I have had a couple of V5X challengers and they have the studs.
Thanks for the help!
