Re: EARLY A BODY OPTIMA CHALLENGE
[Re: amxautox]
#1679567
09/28/14 10:19 PM
09/28/14 10:19 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think an aluminum Gen III Hemi is kinda a prerequisite if you want to win. If that is the case, you will be forced to an aftermarket K member with a rack and pinion to have any chance of a good exhaust. Even a good SB needs fenderwell headers on those cars. The stock suspension can be built to win I am confident there, but, you will also need 500rwhp if you can even be at 2800lbs. To me that is where things get iffy.
Mopar to the bone!!!
[Re: A/MP]
#1679569
09/28/14 10:37 PM
09/28/14 10:37 PM
Posts: 4,323 NY NY
340duster340
NY NY
If you were to use a Valiant/ Cuda for this style protouring race build what would you suggest for front and rear suspension. Keep it ($)reasonable unless you are willing to sponsor the build.
i am putting my 66 dart tougher now with FFI everything. springs i got from espo for the rears (6 leaf) and the t-bars are 1.1 MP units.
i am not sure what the rules are for the optima challenge, but your going to want to reinforce the front UCA/shock mount tower for sure. the early a's are really built like beer cans in that department compared to the later cars.
[Re: jcc]
#1679573
09/29/14 12:40 AM
09/29/14 12:40 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
The recent Sebring Optima race had a well sorted out, all the goodies, lots of aero, 650Hp w/26?lbs of boost Neon, it kept up with the faster cars.
Member, prrc, is already building a pro-touring 63-65 Valiant with a hopped up SRT engine using the stock suspension locations. He's looking to make about 600 or so hp with a 2400 lb car.
[Re: A/MP]
#1679574
09/29/14 11:28 AM
09/29/14 11:28 AM
Posts: 256 USA
Consulier
USA
Do you want to have fun, or be competitive?
If it's for fun, build whatever you can afford. To be competitive, the driver is more important than the car. Spend your money on the driver and the budget for your car will come down significantly.
In either case, there is no reason to cut the suspension off your car. You can be competitive with torsion bars and leaf springs in both classes, but competitive in the under 3k class will be a lot cheaper.
[Re: jcc]
#1679575
09/29/14 11:36 AM
09/29/14 11:36 AM
Posts: 256 USA
Consulier
USA
It was fast in under 3k class, but almost 5 seconds off the overall.
