1998 jeep Cherokee 4.0 cyl head interchange #1677180
09/26/14 10:30 AM
09/26/14 10:30 AM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
I recently purchased a 1998 Cherokee Classic 4.0 with a cracked cylinder head. It is a clean 2wd with only 118K miles.What years of heads will directly bolt on? I am fixing this for my 16yo son who just got his license last week. Thanks!
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: 68GTS383] #1677181
09/26/14 02:32 PM
09/26/14 02:32 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Both '91-95 (casting #7120) and '96-98 (#0630) will work. #7120 is said to be a little beefier.
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: Cooter] #1677182
09/26/14 06:20 PM
09/26/14 06:20 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
Thanks!
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: 68GTS383] #1677183
09/26/14 06:54 PM
09/26/14 06:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I believe the later model stuff will also work, only difference being there is provisions for the coil on plug setup. I don't believe it is in the way though.
68 Barracuda Formula S 340
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: Bad340fish] #1677184
09/26/14 10:09 PM
09/26/14 10:09 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
u need the 0630 head and before bolting on change freeze plugs
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: d-150] #1677185
09/26/14 11:13 PM
09/26/14 11:13 PM
IN
ahy Offline
ahy  Offline
IN
Great vehicles. My daughter's '01 has around 135k and she loves it.
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: ahy] #1677186
09/26/14 11:26 PM
09/26/14 11:26 PM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
My '98 has been great too. Only thing is now I can't get the heater to blow hot. I've flushed out the heater core, and the other water parts. It will get hot till I start the blower, then it just blows cooler and cooler till it's all cold. I've been told about an air direction door that could be not working right.
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: bigblock340power] #1677187
09/27/14 03:22 AM
09/27/14 03:22 AM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
How did you flush out the heater core? Also, are both hoses to the heater core hot with the heat on?
As for later heads on the '98, pretty sure that the '99-04 #0331 heads require a different exhaust manifold. Plus they are known for problems with cracks.
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: Cooter] #1677188
09/27/14 06:00 AM
09/27/14 06:00 AM
Elk Grove, Calif.
Elk Grove, Calif.
Took the heater core lines off at the nipple fittings (on the engine). Flushed them with semi-high pressure water, back and forth till the water ran clean and open. I think the both heater hoses are hot.
Re: 1998 jeep Cherokee 4.0 cyl head interchange [Re: bigblock340power] #1677189
09/29/14 11:16 PM
09/29/14 11:16 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Yeah, sounds like an air door issue.
