Re: 1998 jeep Cherokee 4.0 cyl head interchange
[Re: 68GTS383]
#1677183
09/26/14 06:54 PM
09/26/14 06:54 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I believe the later model stuff will also work, only difference being there is provisions for the coil on plug setup. I don't believe it is in the way though.
68 Barracuda Formula S 340
[Re: Cooter]
#1677188
09/27/14 06:00 AM
09/27/14 06:00 AM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
How did you flush out the heater core? Also, are both hoses to the heater core hot with the heat on?
As for later heads on the '98, pretty sure that the '99-04 #0331 heads require a different exhaust manifold. Plus they are known for problems with cracks.
Took the heater core lines off at the nipple fittings (on the engine). Flushed them with semi-high pressure water, back and forth till the water ran clean and open. I think the both heater hoses are hot.
