1973 D200, stock tire size? #1676634
09/25/14 12:03 AM
09/25/14 12:03 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Can anyone tell me the stock tire size on a 1973 D200, 2wd? Would it have the same front and back?
Re: 1973 D200, stock tire size? [Re: Exit1965] #1676635
09/25/14 01:07 AM
09/25/14 01:07 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
7.50x16.5 tires... 9.50x16.5 optional
All 4 same unless spec'd for traction tread rear tires.
Most would do bigger rear tire for camper back in the day....
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 1973 D200, stock tire size? [Re: dynotune440] #1676636
09/25/14 09:54 AM
09/25/14 09:54 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Thanks!
Re: 1973 D200, stock tire size? [Re: Exit1965] #1676637
09/25/14 12:46 PM
09/25/14 12:46 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Says in your door jamb on the cab.
Re: 1973 D200, stock tire size? [Re: 76dodgeboy] #1676638
09/27/14 09:53 PM
09/27/14 09:53 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I see the vin plate there with some GWV #s on it, but no tire info.
Re: 1973 D200, stock tire size? [Re: 76dodgeboy] #1676639
09/28/14 12:22 AM
09/28/14 12:22 AM
dynotune440 Offline
dynotune440  Offline
Too old, they started that in 77, 78 for sure...
Re: 1973 D200, stock tire size? [Re: dynotune440] #1676640
09/28/14 08:51 AM
09/28/14 08:51 AM
Germany, Berlin
muskote Offline
muskote  Offline
Germany, Berlin
At the early ones it should be listed on the hood tag..., if it´s still there.
You´ll find it also on the "Building Order" sheet, if you´re happy to find it. (under/behind seat, behind door panels, under dash...
Here´s an example of my 73 D100...
Inside Hood
Door
Post Pillar
Building Order
Re: 1973 D200, stock tire size? [Re: muskote] #1676641
09/28/14 12:43 PM
09/28/14 12:43 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I hadn't paid attention. My bad. I think 76 had them but not sure now. Thanks for pointing that out.
Re: 1973 D200, stock tire size? [Re: 76dodgeboy] #1676642
09/28/14 11:03 PM
09/28/14 11:03 PM
IN
ahy Offline
ahy  Offline
IN
I remember a '74 I ran came with 8.00 x 16.5 original. I upped it to 8.75 x 16.5 and it ran that way to around 220k hard miles.
