Re: 71 charger doors in a 73 charger?
[Re: smallstroker]
#167543
12/15/08 01:16 PM
12/15/08 01:16 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
partially correct at least on the way mark posted...more detailed info...
will door close ?... PROBABLY
will front body lines will match ?... yes
will Rear body lines will match ?... no, curved shape neither, and in fact 71/72 doors are about 2 inches higher on rear than 73/74. That's the same reason upper inner panels won't interchange either.
If you are trying to make what I think, R/T doors on 73/74... imposible.. would need to cut the louvers and weld on to door
