'01 Ram 1500 4x4, power steering quit #1675401
09/21/14 10:13 PM
09/21/14 10:13 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Hey guys,
My power steering quit suddenly tonight. I expected to see a blown hose or broken serpentine belt, but a quick look with a flashlight everything looks good. Reservoir has fluid in it. Did my pump just go bad?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: '01 Ram 1500 4x4, power steering quit [Re: GO_Fish] #1675402
09/21/14 10:46 PM
09/21/14 10:46 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Grab the pulley and see if it slides out of the pump.
Re: '01 Ram 1500 4x4, power steering quit [Re: NITROUSN] #1675403
09/22/14 12:00 AM
09/22/14 12:00 AM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Okay, sounds like a plan.
Re: '01 Ram 1500 4x4, power steering quit [Re: GO_Fish] #1675404
09/22/14 10:37 PM
09/22/14 10:37 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
Seemed tight by hand, but a slight twist of a pry bar between the pump and pulley and the shaft popped out. With the shaft snapping off, should the system be flushed before installing the new pump?
Re: '01 Ram 1500 4x4, power steering quit [Re: GO_Fish] #1675405
09/22/14 11:21 PM
09/22/14 11:21 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You could flush it. I am not sure why they snap like that. There are filter kits available. My experience is put a pump on and drive it. Years back we had some new jeeps and a few trucks that broke. Might just be a brittle shaft.
Re: '01 Ram 1500 4x4, power steering quit [Re: NITROUSN] #1675406
09/23/14 12:36 AM
09/23/14 12:36 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I tried to remove a sprocket off my old pump and it snapped off like that. I got a reman at napa and it's been a good pump even with oversize tires.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: '01 Ram 1500 4x4, power steering quit [Re: Silver70] #1675407
09/27/14 08:34 PM
09/27/14 08:34 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I went to the pick & pull and got one cheap for $17. Added a $12 pint of Lucas power steering "honey" and the system was smooth and quiet. Then added regular P/S fluid to top off the system, and now it hums and has occasional dead spots. Back on the road quickly, but not sure how long it will live. Next time NAPA.
