Hyd. Lifters #167531
12/14/08 03:36 PM
12/14/08 03:36 PM
Easton, Kansas
Moparmedic440 Offline OP
Easton, Kansas
Do small block and big blocks use the same hyd. lifter. Thanks
Re: Hyd. Lifters [Re: Moparmedic440] #167532
12/14/08 03:44 PM
12/14/08 03:44 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
yes
Re: Hyd. Lifters [Re: Moparmedic440] #167533
12/14/08 03:56 PM
12/14/08 03:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on the manufacturer, some lifters have the oil groove positioned so that the groove will become exposed at maximum lift if installed in the incorrect block.
Most aftermarket lifters have the groove located to make them interchangeable between BB, SB and AMC.
