Well it's back in the car. #1674516
09/20/14 03:42 PM
09/20/14 03:42 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I'm finally about ready to try this thing again. Hoping for better results this time.
Re: Well it's back in the car. [Re: rt66jim] #1674517
09/20/14 05:11 PM
09/20/14 05:11 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Cool, what are the details on "it" ?
Re: Well it's back in the car. [Re: SpareParts] #1674518
09/20/14 05:56 PM
09/20/14 05:56 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
89 Daytona Chris Alston 4 link chassis certified to 8.50. 416 W2 headed SB, 4:30 83/4, 727 w/4600 TA converter, 950HP ProForm carb, Aeromotive 1000 pump. 2550 lbs w/driver. Should run some mid 9's. I hope.
Re: Well it's back in the car. [Re: rt66jim] #1674519
09/20/14 06:00 PM
09/20/14 06:00 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Pull the belts tight, that should be a lot of fun. Congrats
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Well it's back in the car. [Re: B3422W5] #1674520
09/20/14 07:36 PM
09/20/14 07:36 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thanks Don. So far I can tell there is a problem seeing around the scoop when I stage. Think it needs a periscope.
Re: Well it's back in the car. [Re: rt66jim] #1674521
09/20/14 08:42 PM
09/20/14 08:42 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
GREAT to see you getting out again soon. Have fun and be safe.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Well it's back in the car. [Re: pittsburghracer] #1674522
09/21/14 01:36 AM
09/21/14 01:36 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thanks John. Hope you have your Daytona out again real soon. Jim
Re: Well it's back in the car. [Re: rt66jim] #1674523
09/21/14 10:29 AM
09/21/14 10:29 AM
PA.
"Little"John
"Little"John
PA.
Hopefully I will be posting some updates on my racing future SOON.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Well it's back in the car. [Re: rt66jim] #1674524
09/21/14 11:19 AM
09/21/14 11:19 AM
CheddarHead till October
weedlayer Offline
weedlayer  Offline
Wow Jim, that should be quite the trip!
Re: Well it's back in the car. [Re: rt66jim] #1674525
09/21/14 11:45 AM
09/21/14 11:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Hope it goes well for you... what happened previously
I forget
Re: Well it's back in the car. [Re: MR_P_BODY] #1674526
09/21/14 01:24 PM
09/21/14 01:24 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thanks Ray.
Mike I made a poorly designed oil pan. Lost oil pressure and toasted the bearings. Polished the crank and has new
bearings. I'm using a truck rear sump pan now. I will keep a real close eye on it the first few passes. Jim
