Re: 540 Low Deck with 440-1 345CNC Dyno Results
[Re: Thumperdart]
#1674152
09/19/14 02:19 PM
09/19/14 02:19 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
Chuck.........
Any chance you can post the results of Joe's W5 on the pump after you have it on there? Looking forward to seeing how it does with the new heads on it.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Chuck@Best_Machine]
#1674157
09/19/14 04:29 PM
09/19/14 04:29 PM
Posts: 610 long time lurker, short time p...
PorkyPig
Indy Alum Low Deck Block Indy 440-1 345CNC Heads, Reworked by us Indy 400-2 4150 Intake Quick Fuel 1050 4150 1” HVH Spacer 280ish at .050 Solid Flat Tappet T&D Single Shaft Rockers 1.6 / 1.6 Pushrod Oiled Race Tec12.5 to 1 Comp Pistons .043/.043 Compstar 6.535 Rods K1 4.250 Crank Roll Master Timing Chain Charlie’s Oil Pan Milodon Single Line Oil System
Please tell me that part about it having a Flat Tappet cam is a misprint! Why would someone build an engine with all the rest of the parts listed above, yet not run a roller?
[Re: PorkyPig]
#1674158
09/19/14 06:43 PM
09/19/14 06:43 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Out of interest, did you try different carbs or spacers ? Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Wv68charger]
#1674162
09/19/14 10:13 PM
09/19/14 10:13 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Wait aren't you worried about spinning it that hard...?
NO... It's an aftermarket Low Deck Indy Block..
Don't know if you were being sarcastic or not..
Chris..
[Re: quickd100]
#1674167
09/20/14 09:33 AM
09/20/14 09:33 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
That's pretty stout for pump gas compression and a flat tappet! IMHO That would make a great bracket engine as well. Change oil and plugs and check the lash in the spring and run it!
