Page 3 of 3 1 2 3
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Wv68charger] #1674188
09/20/14 03:48 PM
09/20/14 03:48 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline OP
Wait aren't you worried about spinning it that hard...?
Ha Ha, very funny you know we are not afraid to spin them. Don't make me post you build
I Double dog dare you LOL
OK but you know you cant spin a 572 with -1 heads
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674189
09/20/14 03:51 PM
09/20/14 03:51 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
You said keep it low around 73-7500 right?
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Wv68charger] #1674190
09/20/14 05:00 PM
09/20/14 05:00 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Chuck that motor is a jewel and I love your choice in gaskets!
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: roadhazard] #1674191
09/20/14 06:13 PM
09/20/14 06:13 PM
Thanks Greg keep up the good work
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674192
09/20/14 10:33 PM
09/20/14 10:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do your results vary when using supersuckers and by bigger i assume you mean the 2" ones. From other posts i've read, the feeling seemed to be that head limited motors benefitted more.
Mick
Yep the 2" 4 hole work good, gives the fuel more time to turn down the port rather than hit the floor of the Manifold. None of the Mopar Intakes have enough plenum volume
Curious about wheather or not you`ve done the 2" dominator adapter deal on a 4150 manifold and what you`re results were.........
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: B3422W5] #1674193
09/21/14 07:11 AM
09/21/14 07:11 AM
gregsdart Offline
gregsdart  Offline
I must have missed where it said pump gas. All I read was street/ strip
With a 280 @ .050 cam in at 110 , that equals a 9.39 dynamic CR, cranking compression of 196 psi.
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: gregsdart] #1674194
09/21/14 10:21 AM
09/21/14 10:21 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good work. Thanks for sharing.
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: HardcoreB] #1674195
09/21/14 11:05 AM
09/21/14 11:05 AM
NC
440Jim Offline
440Jim  Offline
NC
Nice results.
Even with the 4150 carb and flat tappet cam it made great power. And I agree the owner could drive it on the street (part throttle) on pump premium gas. Race gas for full throttle would be recommended just to be careful.
I am sure it will spin the tires on the street at less than full throttle!
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: 440Jim] #1674196
09/21/14 11:49 AM
09/21/14 11:49 AM
fullmetaljacket Offline
Exactly what I have done.
I mix when ever in the mood for the cruising fix and pure when I'm about to go racing for sure.
Page 3 of 3 1 2 3
