Dumb question, crank trigger?? #1674031
09/19/14 12:04 AM
09/19/14 12:04 AM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
I'm putting my motor back in and I'm having a brain fart. I'm running a crank trigger and am wondering how to set my timing. Do I set the balancer at zero and then put my distributor pointing at # 1 plug wire or do I set the balancer at 34 degrees and then install my distributor pointing at #1 plug wire? I'm running 34 degrees timing.
Thanks, Clint
Re: Dumb question, crank trigger?? [Re: 80arrow] #1674032
09/19/14 12:14 AM
09/19/14 12:14 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
Re: Dumb question, crank trigger?? [Re: 80arrow] #1674033
09/19/14 12:15 AM
09/19/14 12:15 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
Line up the sensor with the magnet.with the balancer on 34 if that's what you want the timing at. Then line up distributor with number one.
Re: Dumb question, crank trigger?? [Re: a493demon] #1674034
09/19/14 12:16 AM
09/19/14 12:16 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Set the crank to 34 degrees and line up the magnet / pick up.
Have the rotor pointing at #1.
Start and check.
If you're closer than 2 degrees , you're a better man than I.
Re: Dumb question, crank trigger?? [Re: tubtar] #1674035
09/19/14 12:18 AM
09/19/14 12:18 AM
8
80arrow Offline OP
80arrow  Offline OP
Thanks guys.
Re: Dumb question, crank trigger?? [Re: 80arrow] #1674036
09/19/14 01:24 AM
09/19/14 01:24 AM
mi
rbj Offline
rbj  Offline
mi
Make sure to phase the rotor . After you confirm timing. And that polarity of sensor is correct . Digital box full advance , analog box full retard.
