Page 10 of 16 1 2 8 9 10 11 12 15 16
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167122
09/27/11 05:27 PM
09/27/11 05:27 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Hey Mark ,I got it to go 12.004,motor is over powering the tires and the 60 foot times slowed to 1.65 from 1.49.but the new power pulled it thru on the top end..but I still got a few tricks in my bag...planning to go next week to PBIR and get my 11.9..3760 lbs doesn't help.. then she may go up for sale.. Thanks Larry
Re: Time to show your streetrods or rod projects [Re: dynamite] #167123
10/03/11 09:43 PM
10/03/11 09:43 PM
moparx Online content
moparx  Online Content
spent some time over the weekend on the humpback floor. i tried out the 90* master mount i built a while back, and it fits just like i planned. if the old cowl vent mechanism wasn't still attached, it would have clamped in place at the exact location. as it is, it will be 5/8" over toward the centerline and 2" up. the old steering column mount served as a good brace for the mockup however. i took a couple of pics to give an idea. sorry for the quality. i guess i need to get a "new" new camera........
Re: Time to show your streetrods or rod projects [Re: moparx] #167124
10/03/11 09:46 PM
10/03/11 09:46 PM
nother shot......
Re: Time to show your streetrods or rod projects [Re: moparx] #167125
10/03/11 09:48 PM
10/03/11 09:48 PM
general floor view.......
Re: Time to show your streetrods or rod projects [Re: moparx] #167126
10/03/11 09:50 PM
10/03/11 09:50 PM
missing tunnel piece.......
Re: Time to show your streetrods or rod projects [Re: moparx] #167127
10/03/11 09:52 PM
10/03/11 09:52 PM
rearward view......
Re: Time to show your streetrods or rod projects [Re: moparx] #167128
10/03/11 09:54 PM
10/03/11 09:54 PM
last one...... junk shot.......
Re: Time to show your streetrods or rod projects [Re: moparx] #167129
10/03/11 10:18 PM
10/03/11 10:18 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Looks good Moparx! As long as we're showing floors that is what I've been working on also. I know they are not exciting but they are necessary. First pic is the before shot.
Re: Time to show your streetrods or rod projects [Re: B1arno] #167130
10/03/11 10:30 PM
10/03/11 10:30 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Tunnel and dash.
Re: Time to show your streetrods or rod projects [Re: B1arno] #167131
10/03/11 10:36 PM
10/03/11 10:36 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Wheel tubs.
Re: Time to show your streetrods or rod projects [Re: B1arno] #167132
10/03/11 10:39 PM
10/03/11 10:39 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Framework behind seats.
Re: Time to show your streetrods or rod projects [Re: B1arno] #167133
10/03/11 10:48 PM
10/03/11 10:48 PM
gee arno. you have much less RUST to play with than me ! i'm envious ! your framework is 1x1 no ? i like the behind the seat framework.
Re: Time to show your streetrods or rod projects [Re: moparx] #167134
10/03/11 11:08 PM
10/03/11 11:08 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Oh, I have my issues with rust, but all and all it's not to bad. Yes the subfloor is 1x1 tubing. It was started that way when I bought the car and I reworked it to fit what I was doing. I love your tunnel. Did you bend that up or have it done?
Arno
Re: Time to show your streetrods or rod projects [Re: moparx] #167135
10/03/11 11:11 PM
10/03/11 11:11 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
That's really looking good Eric!
Is that the drive shaft loop in the picture or reinforcement for the trans tunnel to mount to ?
Mark
Re: Time to show your streetrods or rod projects [Re: B1arno] #167136
10/03/11 11:18 PM
10/03/11 11:18 PM
Mt. Eden Ky.
Mt. Eden Ky.
Looking good Arno! And is that a four speed I see in there?! 4 link rear!? Cool!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Time to show your streetrods or rod projects [Re: B1arno] #167137
10/04/11 09:37 PM
10/04/11 09:37 PM
Arno
that tunnel was quite the project ! i bent that up the "old school" way..... made a couple of "paper dolls" from poster board. it took a few trys till i was satisfied with the fit. then transfered the pattern to 16ga. sheet. with a BUNCH of clamps, i then formed it around a piece of 12 1/2" pipe. this took a little heat to get it to contour corectly, [as well as a couple of afternoons.....] then trimmed to fit. the driveshaft tunnel was formed cold around a piece of 4 1/2" pipe after clamping a piece of 1/2 x 3" angle to the sheet to keep the "legs" of the tunnel from becoming round. a couple x-tra hands from the neighborhood kids helped a ton ! i am using 16ga. for the floor and tunnel because it was available CHEAP, and it fits the budget.
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167138
10/04/11 09:52 PM
10/04/11 09:52 PM
Mark
mark,the loop is the required 6" from the front joint and is 1/4 x2" strap. it also is used as a reinforcement as you are thinking about. that wasn't a real tough item to bend up[compared to the tunnel !]. at the mid point of the tunnel, above the trans mount, i made a 1 1/2 x 1/2"x 1/8 wall, 12 1/2" diameter tube joining the crossmember together where the removable mount section is. the tunnel will mount to this tube further reinforcing this area. the thought is to make the trans tunnel and driveshaft tunnel a structural part of the chassis.
Re: Time to show your streetrods or rod projects [Re: moparx] #167139
10/08/11 12:02 PM
10/08/11 12:02 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Arno
Man, That came out great! I started to form my own and then a friend told me that he had a slip roller and could do it for me so I took the easy way out. I can see that was a bunch of work!
Arno
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #167140
05/20/12 01:38 AM
05/20/12 01:38 AM
PA
bbrroowwnn Offline
bbrroowwnn  Offline
PA
Here is a pic of my 1929 dodge coupe in the works....340/727/dana35
Re: Time to show your streetrods or rod projects [Re: bbrroowwnn] #167141
05/20/12 01:45 AM
05/20/12 01:45 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
PAUL ITS LOOKING GOOD MAN
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
