Any tricks to pulling door hinge pins?
#1671032
09/14/14 09:24 PM
09/14/14 09:24 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
I want to pull off my doors. I can get the top pin but the bottom is too close to fender/running board to get a swing or punch on it. I soaked them in penetrating oil but can get them to budge, any ideas how to get them out?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Any tricks to pulling door hinge pins?
[Re: AZ_A12_BEE]
#1671033
09/14/14 10:10 PM
09/14/14 10:10 PM
moparpollack
Lil Herman
Lil Herman
85086
No trick for me just used a punch and a hammer.
[Re: AZ_A12_BEE]
#1671036
09/14/14 10:31 PM
09/14/14 10:31 PM
AZ_A12_BEE
Dreaming of the 808
Is it possible to grind the top mushroom head off and drive it down rather than up?
37 Plymouth PU
[Re: AZ_A12_BEE]
#1671037
09/15/14 03:17 PM
09/15/14 03:17 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Second on the air hammer.
[Re: AZ_A12_BEE]
#1671041
09/15/14 10:10 PM
09/15/14 10:10 PM
Posts: 19,408 north of coder
moparx
the pins must be removed toward the top because of the knurled step at the top is usually around 1/16" or so larger than the main pin itself. this is to keep the pin in position in the hinge. if removed by trying to pound it through the bottom, the usual outcome is a gakked up hinge. "if" , for some reason, you were successful at getting it out this way, you would probably have to ream the hinge for an oversize pin[that is if you could find one] so the door would work correctly upon reinstallation. you may even have to make a pin if you couldn't find an oversize one. millions of years ago, i saw a tool similar to the home made one ron shows above that had a screw positioned on the bottom bar and a coresponding hole in the top bar that allowed the top of the pin to pass through as the bottom screw was tightened. the screw was smaller than the pin shaft, and was made from something hard so as to not smash, or swell as it passed through the hinge pin bore. the body of the tool was also formed to fit the hinge so as to properly locate the jack screw. i don't recall the make or model this was for, nor do i know if heat was also required to use this. i would hazzard a guess that when relatively new, the pins would press out without not too much difficulty. but 75 years later, most hinge pins need some extra persuasion. in your case, you may just be ahead to yank the fenders and running boards, even though that task may not be what you want to do. i hope something easier can be devised though.......
[Re: OzHemi]
#1671044
09/15/14 11:07 PM
09/15/14 11:07 PM
moparx
Are you worried about reusing the pins? If not...drill a hole in the top, tap it..and use a slide hammer.
good idea oz !
[Re: AZ_A12_BEE]
#1671047
09/16/14 12:31 PM
09/16/14 12:31 PM
Posts: 752 AZ - The "dry heat" state
71autoxr
The whole door assembly comes off hinges and all with the 8 bolts that hold the hinges to the cab. Then you will have plenty of room to bang away.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
[Re: 71autoxr]
#1671048
09/16/14 02:45 PM
09/16/14 02:45 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
that is true as long as you can get all 8 bolts out, heat may be required to do this as well...
and yes to remove some pins you may need to heat the whole hinge and pin and tap away at the pin. it all depends on how stuck they are. and so much for any paint or bondo in the area.
[Re: Mopar Ron]
#1671049
09/16/14 06:41 PM
09/16/14 06:41 PM
71autoxr
Dave if you are able to get the top pin out, just unbolt the bottom hinge and slide the hinge out of the door jamb "pocket". If the glass is still installed, have a friend help. The fully dressed door is a handful for one person.
