Converting 2002 Ram with 4.7 to 5.7 Hemi #1670629
09/13/14 06:04 PM
09/13/14 06:04 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
What would it take to put a 2004 5.7 Hemi in a 2002 Ram 1500 with a 4.7? I have an 04' Ram 4 x 4 with a wasted body that I want to pull the motor out of and put it in a 2002 Ram 1500 2wd. I'm thinking computer and maybe engine wiring harness. This sound do-able?
Re: Converting 2002 Ram with 4.7 to 5.7 Hemi [Re: STEFF] #1670630
09/13/14 11:10 PM
09/13/14 11:10 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Most newer computers also have the vehicles vin number in it. This can cause problems if you need the vehicle inspected for emissions. Check this out carefully before you make the change.
Re: Converting 2002 Ram with 4.7 to 5.7 Hemi [Re: RalleyA12] #1670631
09/15/14 05:47 PM
09/15/14 05:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
There are guys out there running the 5.7 with the 4.7 computer, just need the harness and engine with all it's accessories, maybe a couple fuel lines and ground wires.
