Re: fuel cell ?????
[Re: max_maniac]
#1669716
09/10/14 03:18 PM
09/10/14 03:18 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
The rulebook does not differentiate between poly and aluminum cells. Just that they require a ground wire.
Re: fuel cell ?????
[Re: all spooled up]
#1669717
09/10/14 04:28 PM
09/10/14 04:28 PM
Posts: 52,972 Romeo MI
MR_P_BODY
im removeing the poly one. and installing a aluminum cell
By rights you dont need the ground if its got good straps or is bolted in place
Re: fuel cell ?????
#1669719
09/10/14 04:47 PM
09/10/14 04:47 PM
MR_P_BODY
i just installed the old ground strap no big deal thanks
Cool.. you wont have any issues
Re: fuel cell ?????
[Re: Al_Alguire]
#1669720
09/10/14 04:53 PM
09/10/14 04:53 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
I recall it being non-metallic require a ground strap. Unless they recently changed the requirement
Re: fuel cell ?????
[Re: 70HemiGTX]
#1669722
09/11/14 12:07 PM
09/11/14 12:07 PM
MR_P_BODY
You should run a ground wire from the filler cap ring to the frame with any cell. Think about this, your plastic cell is an insulator for your filler cap ring, therefore you need the ground. On your aluminum cell, did you put the rubber gaskets between the filler cap rings and the aluminum to seal it up? They are an automatic insulator for the filler cap ring. Yes it may touch the metal, or yea the bolts may touch the metal some where, but not enough to make a "good ground". Put a ground wire on it and you know it is grounded and there fore no arc flash threat.
That's my $1.250.
The thing with ANY plastic tank is as you pour in fuel either by a can or at the pump you are building static electricity and if you touch it with anything weather it be your hand or a metal you will discharge it and it does create a spark and if its in the right area and the F/A ratio is close enough it will light it up.. being that I worked in the fuel lab we had to measure the static build up from MULTIPLE sources... filling the tank, people sliding in and out of the car seat and other things... so we had to have a way to discharge this before the people could fill the tank... doors on the filler tube area is one easy way but we didnt like to have it discharged in that area due to the cap vent... thats PART of the reason you are suppose to take fuel cans out of the car to fill them... you would ground them out when you pick them up to place back in the car.... and we are only talking millivolts here
Re: fuel cell ?????
[Re: GomangoCuda]
#1669724
09/11/14 02:23 PM
09/11/14 02:23 PM
MR_P_BODY
Nope. You may have volts and amps confused. It takes about 500 volts to see a noticeable static spark. 3500 volts to feel it. Rubbing nylon clothes across typical car upholstery can generate 12,000 - 20,000 volts at 50% relative humidity. Less humidity=higher voltages. 20,000 volts can create a spark about 1/4" long. Sliding your butt across your seat and touching a freshly filled fuel container can produce a 40,000-50,000 volts spark. Obviously the amps are extremely low (perhaps 5 milliamps).
Yes... my error.. meant miliamps
