E Body Headers #166916
12/13/08 07:17 PM
12/13/08 07:17 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I'm dropping a 440 into my 73 Cuda with power steering, automatic. The engine came with a very nice set of headers, but they don't look like they will fit. The only numbers I could find on them is 1202L and 1202R.
Thanks for any help you may be able to give.
Re: E Body Headers [Re: jim6346] #166917
12/14/08 01:19 AM
12/14/08 01:19 AM
I have a 72 Cuda that used to have 1 7/8 hooker headers and power steering. I had to grind a little off the power steering manifold for clearance. Just try to fit them in there, then make dents where necessary. I went to 2 inch hookers, and had do put in a few dents as well. TTI has headers that will fit with no dents I think. Headman are good too, as far as fitting. Hookers are known for having to dent them a few times.
Re: E Body Headers #166918
12/14/08 02:23 AM
12/14/08 02:23 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
TTI's will fit with NO dents....except the one in your pocket book!
But...they are well worth it.....can't even compare them to any others I've had.
Re: E Body Headers [Re: superwrench] #166919
12/16/08 10:14 PM
12/16/08 10:14 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Sure you can compare them, Dad!!!!
Remember the old 1-3/4 'El Cheapo's??
Don.
