440 rebuild
#1668981
09/08/14 03:36 PM
09/08/14 03:36 PM
Posts: 416 Georgia
KingTuna
Georgia
I have a 440 out of a 73 New Yorker on the engine stand. Motor looks to be in good shape but needs a rebuild. I have a few questions for you guys in regards to how to rebuild this bad boy. It will be going into the 66 fury, hooked up to the 727 that was in the New Yorker. I will be putting 3.23s in the rear end down the road, but for now it will have the 2.94s. I am looking to make ample amounts of torque to get this big boat moving down the road fairly quickly. Here is the combo I am thinking about.
stealth heads from 440source lunati voodoo 60302 stock cast crank stock rockers and shaft stock distributor rebuild kit from Summit Racing, not sure yet on compression ratio
Would the stock intake and rebuilt thermoquad work well with this setup, or should I go ahead and spend the cash to get the Edelbrock RPM and 750-800 cfm carb.
What would be a good compression ratio to run in this motor? Any suggestions to the combo would be greatly appreciated. This will be my first rebuild. I have a close friend that builds chevy engines frequently that will be helping me assemble.
2014 Ram 1500 Pentastar V6 1966 Fury II 4 door
Re: 440 rebuild
[Re: KingTuna]
#1668982
09/08/14 03:39 PM
09/08/14 03:39 PM
Posts: 416 Georgia
KingTuna
Georgia
Also forgot to ask, would exhaust manifolds work ok with this set up or would heads be needed? If have to use headers, I will use shorties as long tubes in a c body are a royal pain from what I have heard.
Re: 440 rebuild
[Re: KingTuna]
#1668983
09/08/14 03:45 PM
09/08/14 03:45 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
The stealth heads are overkill, but good for upgrades down the road. just order all Summit stuff and roll. T-Chain, re-built kit (hope you don't need a bore, if so get higher compression pistons), the Summit 465-488 cam works good (AMHIK), Used dual palne intake, Holley 750 and headers.. Should pull just fine. Use as many used items as you can(except engine internals) and it should be a cheap build.
Re: 440 rebuild
[Re: Mr.Yuck]
#1668984
09/08/14 05:09 PM
09/08/14 05:09 PM
Posts: 416 Georgia
KingTuna
Georgia
I thought about just keeping the stocks heads on there. They are 346's. If I'm not mistaken, they have the semi-hardened valve seats correct? The motor has 170,000 miles on it, so I'm inclined to think it would be a good idea to rebuild them while they were off.
Re: 440 rebuild
[Re: gch]
#1668988
09/08/14 10:22 PM
09/08/14 10:22 PM
dogdays
Good cam choice. Don't go bigger.
Use the aluminum heads. They won't cost you much more than redoing the 346s.
I hate the heavy stock 440 pistons, but if you are buying a kit try to get the Six Pack pistons, L2355F or something like that. They have a compression distance of 2.05, that will help build compression. DO look at the KB pistons, they have a couple of nice slugs. Everything else you mention is good, if you can afford the Perf RPM that's the one, if not then the CH4B is miles ahead of a Performer, and shouldn't cost an arm and leg. The stock cast iron intake and T-Quad can work too. Put your upfront money INSIDE the engine, intake manifolds and carbs can be upgraded later. At $165 the Firecore distributor is an easy choice.
Find a pair of HP exhaust manifolds and go 2 1/2" back with an H-pipe and my favorite Dynomax Super Turbos, the 17748 or 17749. Why H-pipe? It's less expensive and gets the job done. Nothing wrong with the X, but one can fabricate and install an H in a short time.
I'd keep the 2.94s, it'll be a great cruiser, and FAST on the highway.
R.
Re: 440 rebuild
[Re: RUNCHARGER]
#1668990
09/09/14 11:29 AM
09/09/14 11:29 AM
Posts: 416 Georgia
KingTuna
Georgia
Thank yall for all the input. I'm going to talk to the machine shop sometime this week and see how much they would charge to redo the heads. A friend of mine had a set of 351 modified heads rebuilt by him about a year ago and he charged $500 to rebuild the set. That included putting hardened seats in, but I don't think he had any port work done. I would love to go the stroker route, but 2300 bucks is almost what I hope to build the motor for. I am hoping to keep everything down to around 3000$, or as close as possible. I definitely agree with putting what money I have into the internals. Will look into a set of HP manifolds as well. The New Yorker already had electric ignition on it. Mopar orange box. Definitely will check out that distributor though as I always hear bad things about the orange box.
Re: 440 rebuild
[Re: dogdays]
#1668993
09/09/14 04:22 PM
09/09/14 04:22 PM
Posts: 416 Georgia
KingTuna
Georgia
The New Yorker has the 5 digit speedometer, and it is at 70,000 right now. Car was not parked until 2004, so I'm just going worst case scenario and thinking its more like 170,000. With the valve covers off though, there is nothing that I have seen that scares me. When I take off one the heads it might be a different story though. Good thing is that the motor is free. A little Marvels and a few days wait and she turned right over. I agree with you on the aluminum heads. I believe that is the best way to go. The combustion chambers on the Stealths are also much better than the stock heads as well, correct? I added up the just the major parts alone and right now I am looking at 2,700 dollars. This is the rebuild kit, edelbrock intake, holley 750, stealth heads, voodoo cam & lifters, double roller timing chain, rocker shafts, rocker arms, pushrods. I'm gonna be very happy when this is done but very broke...
Re: 440 rebuild
[Re: dogdays]
#1668998
09/09/14 11:48 PM
09/09/14 11:48 PM
Posts: 3,141 Central NC
gch
Central NC
There is very little functional difference between a 750 vacuum secondary Holley and an 800cfm Edelbrock Thunder Series (AVS) carb.
Saying one will work and one won't on a C-body is just wrong.
R.
If you read my post it says "it will run fine".I was merely stating my experience from the stock carb to a 750 holley on a stock 440 with highway gears.I noticed a huge loss in low end.Granted the stock carb was smaller cfm wise and therefore more responsive.
Re: 440 rebuild
[Re: gch]
#1668999
09/10/14 01:01 PM
09/10/14 01:01 PM
Posts: 416 Georgia
KingTuna
Georgia
I was looking at the Holley 4160 for my carb choice. The stock thermoquad is a 800 or so correct?
Re: 440 rebuild
[Re: KingTuna]
#1669000
09/10/14 02:01 PM
09/10/14 02:01 PM
Posts: 43 League City, TX
BlueGhost
League City, TX
Another option might be stock type pistons and Edelbrock 72cc E-Street heads.
You would get similar compression to stealth heads and flat top pistons, but take advantage of a more modern combustion chamber.
1958 Plymouth Suburban
