Re: FOUND IT! Upgraded pads for the 11.75" Pin caliper...
[Re: ahy]
#1668966
09/09/14 01:54 AM
09/09/14 01:54 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I bite... how much better than carbon mettalic?
The carbon metallic pads are about on par with the Hawk HPS.
Everything above the yellow stuff will be a step up. The Porterfield r4-s is a clubsport style pad and the rest are race pads.
[Re: BigBlockMopar]
#1668968
09/09/14 07:24 AM
09/09/14 07:24 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I run the Hawks HPS pads on my '73 Dart but can't say I'm that impressed (anymore).
- '73 Chrysler calipers with '73 11.75" rotors, - Alum. 15/16" MC - Stock prop.valve - Rear brakes are stock 2.5" wide 10" dia drums.
I use to run the hawk's hps then i switched over to the porterfield's. it was almost night and day - you should try them - they are around the same price
[Re: BigBlockMopar]
#1668969
09/09/14 01:44 PM
09/09/14 01:44 PM
AlexP
Houston, Tx
Along with a soft tire swap I thought it had solved the rear brake-bias my car had awhile ago. But I've recently changed tires on my car and the rear brake-bias is back again when braking hard and suddenly, even on dry roads. (Previous tires had a 200 threadwear rating, the current ones have 280 orso, but seem a bit older.)
I would move to an adjustable proportioning valve.
Are the rear wheel cylinders fairly new?
