Starter cable routing... #1668263
09/06/14 11:44 PM
09/06/14 11:44 PM
ky hills
thehemikid Offline OP
ky hills
Does the battery cable go over or under the speedometer cable? (70 B-body Hemi 4spd) I thought it might go under sense the z-bar lever moves into that area.
Re: Starter cable routing... [Re: thehemikid] #1668264
09/07/14 12:55 PM
09/07/14 12:55 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
Pretty sure it goes under as there are two brackets that secure the battery cable to the inner fender and frame rail.
Re: Starter cable routing... [Re: 469runner] #1668265
09/07/14 06:33 PM
09/07/14 06:33 PM
ky hills
ky hills
That make sense. I knew about the lower bracket, but remembered I didn't like how it routed the cable in relation to the starter & header tube (last time I routed) but had forgot about the upper bracket. Now that you mentioned it, that rung a bell, (that sounded like D'oh) , then remembered what this hole was fur. Thanks.
