Re: ??? about tranny in 93 Dakota with a 5.2L
[Re: Dakotamecrazy]
#1667532
09/05/14 10:55 AM
09/05/14 10:55 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
How many miles on this unit, how does the fluid look, any other abnormalities noted? Even little things that may seem unrelated could help diagnose a problem. Like a slower than normal reverse engagement when hot or the like.
[Re: Dakotamecrazy]
#1667534
09/11/14 09:12 AM
09/11/14 09:12 AM
Guitar Jones
The title and odometer show 226,000 but allegedly it was rebuilt. Cosmetically everything looks clean but not quite sure on the rebuild. The fluid looks and smells a little burnt. I put some seafoam trans tune up in the other day. This weekend I am going to change the fluid and filter and see if anything changes. Does anyone know of any good shops that build torque converters and valve bodies for this transmission?
Thanks Chris
Google PATC, they have a huge amount of stuff for those transmissions.
[Re: Guitar Jones]
#1667535
09/13/14 04:09 PM
09/13/14 04:09 PM
Posts: 4,990 new jersey usa
11secdart
new jersey usa
I have a 92 D150 with the 5.2 318 and 518 automatic, the trans was changed under warranty years ago by Chrysler, A few years ago I pulled the trans and had a Mopar Performance shift kit installed it made a big difference and shifts hard 1st to 2nd. I was going to buy an aftermarket convertor for it but Lenny at Ultimate rebuilt my stock lock up convertor and increased the stall speed and I picked up a little over a tenth in 60ft times. From 2.20s to high 2.0s with a best of 2.05. btw truck runs consistent 15.20s in good air 30s in heat.
