Front and rear backspacingt for 68 Charger Nascar look #166705
12/12/08 08:43 PM
12/12/08 08:43 PM
Northern OH
rapom Offline OP
rapom  Offline OP
Northern OH
I just bought a 68 Charger and would like to do the nascar look with aluminum slots. I'm kind of looking for a tall wide front tire plus since I'm using 15"'s for rims I would like to know the best backspacing. I'm think that my backspacing in the rear will about 3 3/4 to 4" with 15x8.5" with 315/60/15's but I'm not sure about the front?
Re: Front and rear backspacingt for 68 Charger Nascar look [Re: rapom] #166706
12/13/08 10:33 AM
12/13/08 10:33 AM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
All I got was a red X. But just to tell you it is not going to happen with a 4" or less backspace unless you are putting on air shocks.
You will need at least 5-5.5 inches
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Front and rear backspacingt for 68 Charger Nascar look [Re: HealthServices] #166707
12/13/08 01:20 PM
12/13/08 01:20 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
And I don't even think a 315 width tire will fit under the car unless you have moved the springs or mini-tubbed it..
Also, a 315 width tire is way too wide for a 8.5" rim. About the widest tire rated for that width rim would be a 275/60 IMO..
