Real World MPG 98 Durango 5.2 ?
#1666411
09/02/14 03:44 AM
09/02/14 03:44 AM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
Ok you guys/gals that own or have owned 5.2 Durango's..Will a 98 Durango with a 5.2 get 15-18mpg highway if driven 60-65mph? Not sure yet but think it has 3.55s with 31/10.50/15's and is 100% stock.. also it has the select-trac 242 t-case.
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
Re: Real World MPG 98 Durango 5.2 ?
[Re: SuperStockWagon]
#1666412
09/02/14 01:47 PM
09/02/14 01:47 PM
Posts: 546 Gilman, IA
sabbfan
Gilman, IA
It should, I had a similar year Durango with the 5.9 and got around 16 with it.
2012 Ram 2500 Crew Cab 4x4 5.7 Hemi 2011 Dodge Durango 3.6L 2009 Dodge Caliber 1.8L 5 speed 1970 Super Bee-someday!
#1666413
09/02/14 02:31 PM
09/02/14 02:31 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Probably get 17 or 18 with the cruise set on 65 on level ground.
Switch to a 235 75 15 tire will help a lot and be cheaper to buy, those 31-10.50 make a lot of drag.
Get a set of the orange 4.6 ford fuel injectors at the JY for a little MPG bump.
a 205 t-stat helps.
[Re: HotRodDave]
#1666414
09/02/14 04:55 PM
09/02/14 04:55 PM
SuperStockWagon
Emmett, Idaho
Thanks guys..hoping it has 3.92's with the 31 10.50's,if it has 3.55's will switch to smaller tire. Its going to be mainly used in town shuttling kids.
#1666415
09/02/14 05:28 PM
09/02/14 05:28 PM
HotRodDave
Kalispell Mt.
The 3.92 and big tires really put a hit on the mpg. It is the width of the tire more than the height. I never realized it till pushing my wifes around the shop, waaaay harder to push with the wide ones when the steering wheel is turned even a little bit, even straight pushing it was noticably harder. I have owned and driven several of them and trust me you do not want the 3.92 even for town driving, the performance difference is almost imperceptible. A 318 with a 44re and 3.55s is faster than the R/T I have now.
#1666416
09/02/14 07:25 PM
09/02/14 07:25 PM
Posts: 3,058 N.W. Florida
Fat_Mike
N.W. Florida
A 4X4 might get 15 MPG, but I wouldn't bet on anything above that. Edit: Don't be surprised if you get slightly less...
[Re: Fat_Mike]
#1666417
09/02/14 08:57 PM
09/02/14 08:57 PM
Posts: 1,049 ohio
all spooled up
ohio
my 2000 5.9 4x4 3.55 gears 31/10.5 tires has got 19 mpg on flat land at 65 mph and has 190.000 miles on her.
[Re: poorboy]
#1666420
09/03/14 01:38 AM
09/03/14 01:38 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Yes, the around town stuff is the killer, Highway should be in the 14-15 range. If around town shuffling the kids is what you intend to do, buy a minivan, neon or PT Cruiser..
[Re: poorboy]
#1666421
09/03/14 03:06 PM
09/03/14 03:06 PM
HotRodDave
Kalispell Mt.
It might get 15-18 on the highway, but around town, hauling kids from point a to point b, expect 10 mpg, maybe a little less, and that will depend hugely on how its driven. That is a lot of mass to get rolling after the stop light, every other block. Gene
Very true, my wife would get 8 mpg average in her 2000 5.9 with 3.92 (not R/T) while I would get consistent 16.5 every time I drove it.
[Re: HotRodDave]
#1666422
09/03/14 06:22 PM
09/03/14 06:22 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
My 99 5.9 got about 11 or so in town.Highway I would get about 16 to 17.Now when the wife drove it was lucky to get 8 in town.Rocky
Chrysler Firepower
[Re: RODHALL]
#1666425
09/04/14 09:33 AM
09/04/14 09:33 AM
Posts: 7,327 Toronto (YYZ) Ontario
YYZ
depends on how it is driven... heavy right foot, always panic stopping... 8-10 would be my guess.. easy on the gas, able to let it roll into corners and stops, not jerking it all over the road... 16-18 maybe even 19 or 20 could be had...
That's about right.
Points of comparison are a pair of '99s - my buddy's 5.2/4WD/3.92s that he bought new (and still has) and my former 5.9/4WD/3.55s
Mileage was worse with 235/75/15 snows than with the 31s - an upgrade to the later 16" rims with a narrow tread and low rolling resistance tire would probably help.
The Durangos are heavy - 5500# IIRC and larger than the Grand Cherokees. Though for whatever reason they seem to be disproportionately hard on fuel for what they are.
[Re: YYZ]
#1666426
09/04/14 12:32 PM
09/04/14 12:32 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
My '98 5.2/4x4/SLT/3.55/235/75-15 tires weighs 4800lbs according to the grain scale. 157k miles, bought new in 98.
Gets 11-12 in town and at 70mph, 18mpg. Slow it down to 60 and I have been over 20mpg with it.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: HotRodDave]
#1666427
09/04/14 11:09 PM
09/04/14 11:09 PM
Posts: 1,562 Manistee, Michigan.
High Impact
Manistee, Michigan.
a 205 t-stat helps.
Tell me more about these injector's and why it would be better. I imagine you've tried it so what was the out come??
I just bought a beautiful 99 Durango with 66,000 miles and a seized up engine. Not sure why it seized on the people but Im gonna be replacing it with a low mileage 5.2 from a 97 Dodge truck. I already replaced the upper intake gaskets so that's done and im gonna pull the pan to make sure its sludge free and probably install a new oil pump for cheap insurance but wondered about what else I should do to make it better.
[Re: High Impact]
#1666428
09/05/14 11:56 AM
09/05/14 11:56 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I averaged 18 in mine, not highway, just mostly local and shorter trips.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: High Impact]
#1666430
09/06/14 09:50 AM
09/06/14 09:50 AM
YYZ
a 205 t-stat helps.
While you have the engine out, it's a good idea to carefully flush the cooling system. That generation of Durango is notorious for clogging up heater cores for whatever reason.
