Re: lots of brake questions!!!!
[Re: birdtracker]
#1665300
08/29/14 11:34 PM
08/29/14 11:34 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Put an manually adjustable valve in the rear brake line. Adjust as needed to balance the braking.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: birdtracker]
#1665301
08/29/14 11:38 PM
08/29/14 11:38 PM
Posts: 22,696 Bitopia
jcc
Bitopia
1. Maybe not if everything else is perfectly sized and nothing changes weight, driving, pad compounds, etc, which means yes 2. Need a lot more info to give a better answer Tires F/R, Dia, Disc Dia, Caliper specs, pedal ratio is stock?, use, etc Others will chime in and need this info.
[Re: jcc]
#1665302
08/30/14 12:07 AM
08/30/14 12:07 AM
birdtracker
1. Tires front 25 X 3 Goodyear front runners rears Goodyear 14 X 32 X 15 2. Factory front discs 3. Drag race 95% street drive 5%
Birdtracker
[Re: birdtracker]
#1665305
08/30/14 01:35 AM
08/30/14 01:35 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I read that thread. I understand alot of it. What I don't understand is when they ask how hard I want to push on the pedal. I have no clue unless I set up and recorded pedal force. So I put an aluminum master cylinder on my car with 1 1/8 bore. It doesn't stop very well. I almost ran over a track person who walked out in front of me leaving the burnout box going to the line. I checked to make sure the lines were in the right spot. I think I will try a 15/16 bore master cylinder tomorrow. thanks. Birdtracker
How much MC pressure are you getting? From what I was told you should have at least 1000 psi. With a large bore like that, usually it takes quite a bit of force to stop.
[Re: birdtracker]
#1665306
08/30/14 02:46 AM
08/30/14 02:46 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Birdtracker
Which factory disc brakes? 4 piston KH or one piston floating? Need diameters of piston(s)
What are the number of pistons in the rear and their exact diameter?
[Re: BigBlockMopar]
#1665308
08/30/14 12:17 PM
08/30/14 12:17 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I have a basic 73-76 A-body disk brake setup on my car, but with the later model 2.75" piston front calipers and 11.75" rotors.
I have the 15/16" master cylinder from Dr Diff. Stops well and doesn't even come close to bottoming the master cylinder. A-bodies with power brakes came with this size from the factory, and for some reason manual brakes came with 1 1/32" Master cylinders.
I would run the 15/16".
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: birdtracker]
#1665313
08/31/14 12:43 AM
08/31/14 12:43 AM
amxautox
does it have a metering valve? is the plunger pulled for bleeding?
Tom
author unknown
