New Charger/Challenger wheels on D-100 #1665246
08/29/14 04:44 PM
08/29/14 04:44 PM
Austin, TX
lunacy Offline OP
lunacy  Offline OP
Austin, TX
Has anyone tried some 2008+ OEM Dodge Challenger or Charger aluminum wheels on an older truck with the 5 on 4.5 bolt pattern. I am assuming that the hub would make it not fit on the front without a large spacer, which it probably needs for backspacing anyway, but I thought I would ask. I have no experience with the car wheels, and only limited with the newer truck stuff.
Re: New Charger/Challenger wheels on D-100 [Re: lunacy] #1665247
08/29/14 10:29 PM
08/29/14 10:29 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
New Charger/Challenger wheels aren't 5 x 4.5" (or 5 x 114.3 mm). They're like 5 x 115 mm. I've heard in some instances that bad things happen even with that .7 mm difference.
Re: New Charger/Challenger wheels on D-100 [Re: MuuMuu101] #1665248
08/30/14 10:34 PM
08/30/14 10:34 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
intrepid wheels work with a 1 inch spacer and you can find them up to 17 inch....
