What's the best way to strip paint off interior panels #1664729
08/28/14 11:00 AM
08/28/14 11:00 AM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
I have a 70 challenger convertible. when I bought it the interior panels were spray painted black they are originally white. The paint is slightly peeling off does anyone know a good way of removing the black paint without destroying the panel. I want to restore them back to the white panels. Thanks. Mike
1970 challenger convertible
Re: What's the best way to strip paint off interior panels [Re: mikeporp] #1664730
08/28/14 11:28 AM
08/28/14 11:28 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Brake fluid.
Works on grill plastic
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: What's the best way to strip paint off interior panels [Re: mikeporp] #1664731
08/28/14 08:12 PM
08/28/14 08:12 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
yep , soak paper towels with brake fluid and apply.
Re: What's the best way to strip paint off interior panels [Re: mikeporp] #1664732
08/28/14 08:29 PM
08/28/14 08:29 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: What's the best way to strip paint off interior panels [Re: charles6970] #1664733
08/28/14 08:30 PM
08/28/14 08:30 PM
IL us
I
ink Offline
ink  Offline
I
IL us
not to hijack this post, but i have had over spray ( not much, haze) on my mint challenger dash pad for 18 years you think this would be to harsh on vinyl
Re: What's the best way to strip paint off interior panels [Re: ink] #1664734
08/28/14 08:45 PM
08/28/14 08:45 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Power washer.
Re: What's the best way to strip paint off interior panels [Re: Finoke] #1664735
08/29/14 12:30 AM
08/29/14 12:30 AM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Thanks for all the good ideas. I will start with the power washer and move on from there, as the paint is flaking already.
Re: What's the best way to strip paint off interior panels [Re: mikeporp] #1664736
08/29/14 12:48 AM
08/29/14 12:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
When getting off the subject of E-body door panels and stripping plastic parts of paint etc. you MUST keep in mind that all plastics are not created equally! We have ABS, Styrene, PVC, Polypropylene, Nylon, Butyrate, etc. in these cars and all are affected differently by various chemicals.
Some are virtually indestructible by chemicals (Polyethylene/Polypropylene) while others like Styrene will melt quite easily even from some of the milder chemicals.
So, you need to correctly identify the plastic material the part is made of before applying any chemicals.
Re: What's the best way to strip paint off interior panels [Re: Finoke] #1664737
08/30/14 11:56 AM
08/30/14 11:56 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Power washer.
So useful of a tool for restorations.
Re: What's the best way to strip paint off interior panels [Re: Challenger 1] #1664738
08/30/14 01:19 PM
08/30/14 01:19 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Power washer.
I don't know how I got along without one for as long as I did. Big initial investment but over time they can save you a lot of money in time savings (works MUCH faster and cleans better than most chemicals), materials costs (no need for a bunch of expensive harsh chemicals), and gentile parts cleaning without undue damage (doesn't harm most surfaces).
Re: What's the best way to strip paint off interior panels [Re: ScottSmith_Harms] #1664739
08/30/14 03:50 PM
08/30/14 03:50 PM
Houston Texas, USA
markfh52 Offline
markfh52  Offline
Houston Texas, USA
To add to ScottSmith about using chemicals on plastics or for that matter any material as they say always test on a small spot or area that won't show or do too much damage first.
Re: What's the best way to strip paint off interior panels [Re: markfh52] #1664740
08/31/14 02:12 PM
08/31/14 02:12 PM
Alberta
rustbuckett68 Offline
Alberta
Testing is a must. I've used 'easy off' (the old style)oven spray for stripping paint off model cars, works great. But as said, check on the back first!
Re: What's the best way to strip paint off interior panels [Re: mikeporp] #1664741
08/31/14 04:15 PM
08/31/14 04:15 PM
AZ - The "dry heat" state
71autoxr Offline
71autoxr  Offline
Perfect application for soda blasting.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
