Headers for 98-03 Dakota #1664068
08/26/14 07:12 PM
08/26/14 07:12 PM
In the Middle
roadntrack Offline OP
In the Middle
Has anyone or will anyone ever make a DECENT set of
longtubes for a 2wd 5.9 Dakota?
Remember when cars were FUN?
Re: Headers for 98-03 Dakota [Re: roadntrack] #1664069
08/28/14 01:12 PM
08/28/14 01:12 PM
In the Middle
In the Middle
Nobody has put headers on one of these???
Anyone tried the Southeast Performance set?
Re: Headers for 98-03 Dakota [Re: roadntrack] #1664070
08/28/14 01:48 PM
08/28/14 01:48 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
A few months ago I seen a Ram with headers in the wrecking yard and the flanges were cracked on both sides.......so, I understand what you mean when you say "decent".
Apparently the '92 318 Magnums had the best exhaust manifold with a larger opening vs the later versions. Might be something to look into if you can't find headers.
What else is done to the exhaust, or are you planning?
Mo' Farts
Moderated by "tbagger".
Re: Headers for 98-03 Dakota [Re: Grizzly] #1664071
08/28/14 01:56 PM
08/28/14 01:56 PM
In the Middle
In the Middle
Yes I think the '92 had a 2.25 outlet and everything later
is 1.875? Crazy small!
I have thought about trying to find '92s but guessing most would be
rusted to hell or warped by now?
Re: Headers for 98-03 Dakota [Re: roadntrack] #1664072
08/28/14 02:12 PM
08/28/14 02:12 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Meh, maybe not: takes probably a hundred years to warp 35 pounds of cast iron.
Throw your catalytic convertor in the garbage and go true dual, if you have'nt already. Makes a noticible difference.
Electric fan is another worthwhile upgrade.
Mo' Farts
Re: Headers for 98-03 Dakota [Re: Grizzly] #1664073
08/28/14 04:11 PM
08/28/14 04:11 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Look at the Hooker 5803. For earlier Dakotas but should fit the later ones also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Headers for 98-03 Dakota [Re: 71yelladustr] #1664074
08/28/14 05:22 PM
08/28/14 05:22 PM
In the Middle
In the Middle
Thanks,has anyone tried these on a 97-03?
I dont want to be the "test pilot"
You would think if they did fit, Hooker would advertise
as such?
Re: Headers for 98-03 Dakota [Re: roadntrack] #1664075
08/28/14 11:22 PM
08/28/14 11:22 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
A 97 Dakota is completely different then a 96, I'd really be surprised if the headers for the older truck would fit the newer one. Sorry, Gene
Re: Headers for 98-03 Dakota [Re: poorboy] #1664076
08/28/14 11:34 PM
08/28/14 11:34 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
There's some sets of long tubes out there, but they're a pain to install. Mopar performance 'PPH' headers are a mid-length, tri-y design that will support 450+ RWHP. They can be found used for $400-ish.
Spintech makes a nicer mid-length for about 700 that will support a TON of power.
Both sets install easily from the top in about an hour
**Photobucket sucks**
Re: Headers for 98-03 Dakota [Re: 70Cuda383] #1664077
08/29/14 12:18 AM
08/29/14 12:18 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
I put a set of Edelbrock TES headers on my 99 R/T. They are only slightly longer than a shorty set, but they came with a y pipe also. I put them on while I had the front clip off. I had to adapt and modify a few things because they weren't exactly made for the R/T. I had to cut and re-weld the y pipe, and also add extra o2 bungs because they didn't come with enough. I also had re-done my cat in 3" so it was a complete custom job. They are nice, and really had no fitment issues. Hope that helps...
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
