Dakota Drop Spindles
#1663587
08/25/14 08:25 PM
08/25/14 08:25 PM
Posts: 84 MO
C_Notch
MO
Who has done this? or who has done this lately? what was your experience? What year truck and what are all the parts that you used? thanks in advance
Re: Dakota Drop Spindles
[Re: 76dodgeboy]
#1663595
08/27/14 01:46 AM
08/27/14 01:46 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
What Spindles do you have? I've never heard of shaving ANY parts for them to fit that I remember.
I have heard of using one year group of Dakota spindle & the hole for the tie rod needed reamed with a tapered ream I'm not sure which ones though
You may have to trim the LCA if using a Van LCA so the wheel will clear when you turn the wheels right to left
[Re: BulletBob]
#1663598
08/27/14 01:22 PM
08/27/14 01:22 PM
Posts: 84 MO
C_Notch
MO
"Do you have Belltech spindles or Chassis tech?"
BulletBob, I have the Belltech spindles. What year was the truck you put your on?
I have been driving the truck for 2years or so with cut coils and van lca's. the spindles shouldn't change that any of that just the height of where the wheels mount.
[Re: C_Notch]
#1663604
08/31/14 01:19 AM
08/31/14 01:19 AM
Posts: 248 Amarillo, Tx
ramblebee
Amarillo, Tx
Ramblebee, i am planning on grinding it down a little. how close is the tierod end boot to the rotor? or does the dust shield block it?
The boot wasnt making contact with the dust shield in that pic, it just appears that way.
[Re: ramblebee]
#1663605
08/31/14 01:27 AM
08/31/14 01:27 AM
Posts: 84 MO
C_Notch
MO
Thank you. good to know.
[Re: 76dodgeboy]
#1663610
09/24/14 03:47 PM
09/24/14 03:47 PM
Posts: 300 MA
Greg55_99
MA
Info from ElPolako at Industsrial Chassis: "We have found that if you use the BellTech spindles, you are limited to the stock Dakota rotors. The D-series truck rotors will hit the tie rod. BellTech has not only raised and shortened the steering arm, but now have moved it outboard. This has caused an interference issue, we have not had this issue with the spindles from Airbagit." http://www.industrialchassisinc.com/?page_id=281Greg
