Re: 1970 Challenger RT/SE - A resurection coming to life
[Re: p d'ro]
#1662009
08/21/14 04:28 PM
08/21/14 04:28 PM
Posts: 21,453 It's a dry heat
gtx6970
It's a dry heat
What a turn around. Very nice. How does it run?
Dont know yet. tires on it are junk and new ones just showed up this afternoon. It goes in for exhaust 1st of next week . But I had it running for a while monday to break the cam in and it sounds REAL good. Shortblock is actually a 1965 426 wedge with closed chamber heads with just the slightest bit of port work. and we figure it has about 9.5 compression . Cam is a comp cam 270 470 so it has a pretty tame idle Induction setup is all brand new from Sixpack Performance, intake to air cleaner.
[Re: MoparJunkie]
#1662012
08/28/14 09:34 AM
08/28/14 09:34 AM
gtx6970
It's a dry heat
Nice!!!! Looks good, Bill. I should have the U code Challenger done this weekend...Completely. After that Jess and I wanna come up and see your place. We need to get together on what your schedule looks like and plan something.
Come on up, just give me a couple days notice. My daughters Golf matches and 2nd daughters volleyball team games are going full bore right now till late Oct . So on golf match / game days I am usually gone by 3.30- or 4 Or weekends are good to
Monday the owner heard it run for the 1st time since 1994 ,,he was smilen ear to ear when he left
[Re: gtx6970]
#1662013
09/02/14 10:53 PM
09/02/14 10:53 PM
gtx6970
It's a dry heat
Well, Today was a very good day. About 3 pm today , it moved under it's own power for the 1st time since approx 1994. Cars owner was pumped to say the least . Weather permitting, It goes out tomorrow for a little test drive / shake down run. Then bring it back in and go over a few things, then maybe a longer test drive will be in order
Re: 1970 Challenger RT/SE - A resurection GONE
[Re: gtx6970]
#1662016
09/22/14 06:05 PM
09/22/14 06:05 PM
gtx6970
It's a dry heat
A parting shot.
He fired it up and drove it home sunday afternoon
It's far from perfect , exterior wise nothing changed. It does have a tad bit of rust in the lower quarter right behind the door,,,,,,,But He plans to drive the snot out of it just the way it is as time allows. Maybe next year or so we'll address the rust and do a exterior repaint. The exterior was painted in 1986 and has not been touched since.
Although I will probably get it back in the next month or so to address a few bugs ,,( I think I have a valve cover leaking on the drivers side,,,not real impressed with the so called improved style gaskets )
Irregardless,,,,,,,,,He was all giddy when he left in it.
