Hotchkis TVS, Brakes, and Rear End Install
#1661310
08/20/14 04:53 AM
08/20/14 04:53 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
So, in the next couple of weeks I am going to make the leap and start taking the Dart apart so that I can install my TVS, Doctor Diff front brakes, and 8 3/4 rear end. I'd just like your opinions, advice, and parts you think I'll need (I may be forgetting some) so that I can eliminate as much down time as possible. The goal is to get the car running again before October. So here I go... Chassis and Suspension: So, as far as chassis and suspension goes, as mentioned earlier, I already have the Hotchkis TVS. I also purchased their subframe connectors and LCA pivot shaft and bushing kit. I was thinking about just installing the UCA, strut rods, and steering rods while holding off on welding the sway bars and subframe connectors till after the car is driving. On the side, I purchased a set of 1.06" T-bars from Firm Feel that should be swapped in at the same time since the LCA have to come out for new bushings. Are there any other parts I'm forgetting that I need to replace to completely rebuild the front suspension? Brakes: So for the front brakes, I will be using Dr Diff's 13" rotor kit with the "Brembo-style" calipers. I already have them at home, but what would be the easiest way of assembling that? Should I install the spindle first or put the brakes on the spindle and install the whole sub-assembly with the UCA? Also, does anyone have any recommendations for MC's? The one I have is a 2-bolt 1 1/32", and I'm not sure if that will cut it. And since I have the KH discs and am eliminating the drums, do I need to change out the distribution block? I'm still uncertain at this point. The rear brakes are almost done. Everything's bolted on, but I just need to figure out how the 11.7" kit with Cobra calipers connects to my stock brake lines. Or, do I need to modify them? Anyone have pictures or help? Cass gave me the the hardware and connections with some instructions, but I'm a visual learner. I have parking brake lines too. 8 3/4 Rear End: The 8 3/4 has 3.55 gears and an Eaton TrueTrac in it. I just completely assembled it, adjusted for play, and filled it up with oil on Friday. It just needs a break in. I installed a 7290 yoke on it but am unsure at the moment of what the yoke is on my driveshaft. I'm guessing it may be a 1350 and I believe Dr Diff sells a proper U-Joint. I know I'm going to have to get my driveshaft cut but I'll probably get to that when the rear end is back in the car. I'm guessing the shop is going to want the driveshaft measured their way. Is it possible to install the 8 3/4 at the same time as the leaf springs or should the leaf springs be bolted on beforehand? Wheels and Tires: For wheels, I was going to purchase an 18x9-10" set with 275/35/18 tires all the way around. They're going to be two piece wheels so I can set my ideal back spacing/offset. I'm just unsure about the best means of doing so. I'm guessing, bear minimum, I may have to roll my fenders to get everything to fit. Luckily, I've got a lot of people who want to help me with this car. I've got my uncle (retired body work guy), my friend from the baja club who was helping me 2 years ago, and a couple of my coworkers so I won't be doing some of this alone. I don't work Friday-Sundays and finish work at 2pm everyday so, luckily, I've got some time to work on this. I know I kind of just threw out a bunch of information at you guys but I appreciate your guys' knowledge and support. Thank you for everything.
Re: Hotchkis TVS, Brakes, and Rear End Install
[Re: MuuMuu101]
#1661311
08/20/14 10:12 AM
08/20/14 10:12 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Exciting stuff!
Suspension and chassis: Have you recently replaced ball joints and pitman/idler arms? And are you using factory LCA's? You could brace the LCA's (AR Engineering kit from firm feel). You could also weld up and brace the k member, if you want to go so far as to take it out (AR engineering kit from firm feel)
Brakes: I'm not familiar with the piston sizes in those brembo calipers. The cobra calipers are well sized for the rear. I would recommend no distribution block. Just a straight line back. And a t fitting for the front. Find out front piston sizes and run the math sheet. Your master may be fine. I run a 15/16 2 bolt I got from dr diff. The 15/16 might be a better size for you. Though If I were you, I would start with the master you have and change if you feel you need it after running. Rear brakes: I run braided lines to my rear calipers for ease of working on them. Did dr diff send you a set? If not, see if the front braided brake line part number will work (I used same PN braided on all 4).
Wheels: You're going to have to nail your back spacing if you're going to get 275/35/18's to fit square. I'm unfamiliar with 2 piece wheels- but don't you need new cylinders to change offset? Sounds expensive to swap sets? What size wheels do you have now? How do they fit? I run 265/40/18 square on the street (I like the taller tire), and 275/35 fit as well. I'm running +45mm offset in the front(7.2" back spacing), and they rub the frame and the wheel well at about the same time (around 1.25 turn of wheel). I lost turning radius. If you don't go so low, you can run less offset. The rears are tight as well both inner and outer wheel tubs have tire rub marks from tire rubbing. 60.5" width rear with +45mm offset there as well. Also running dr diff offset leaf spring hangers (would be in leaf springs if not)
Cheap way to find perfect fit is to get a high offset wheel of the size and tire you want, and use spacers until you find the 'perfect' location in the wheel well. Subtract the spacer width from the offset and you're done. Where are you located? I have a 18x9.5 +45 spare laying around.
Hope that helps a bit.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: MuuMuu101]
#1661312
08/20/14 10:24 AM
08/20/14 10:24 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I just did what you are about to do to your car earlier this year. I had a local shop tackle most of the suspension stuff though but here are some suggestions. Mind you I have an Ebody but pretty much using similar parts Front end Hotchkis: Get some grade 8 or higher button head bolts for the tie rods because you might need them in case you need clearance at the wheel due to the tie rod bumpsteer spacers. I ended up not using the hotchkis aluminum spacers and was able to get shorter steel spacers at the hardware store. I am using a 10.5" wheel so you might not need this for a narrower combo. I would also get the rubber booties for the rod ends as well. brakes: I used an aluminum MC from a dodge truck but I have hydroboost though. The pedal feel is great but I can't heel toe anymore as it grabs way too quick. I just changed my driving style. I still have to swap to Carbotechs Cass sent me another distribution block to use, I would email him again. 8 3/4: only thing I did different was get 1350 u joints on both ends. wheels: I would get 2 rain wheels and tires with deepest offset and using a variety of aluminum spacers to find the exact offset you need front and rear. You might be surprised that a wider tire might fit! I rolled my fenders too. Hope that helps!
[Re: MuuMuu101]
#1661314
08/20/14 12:39 PM
08/20/14 12:39 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The front and rear suspension installation is a weekend project. If you were closer I'd swing by and help you knock it out. The rear brakes lines will require a double flare tool to attach them to the calipers. You will need to find a flexible (rubber or (preferably) braided) line to connect each side to the calipers. That will allow them to move about (they are sliders) without breaking the line. I've got everything you need to do the install and the shop space to do it. Bring it on out here and we'll get it done.
[Re: Uhcoog1]
#1661315
08/20/14 07:39 PM
08/20/14 07:39 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Exciting stuff!
I haven't rebuilt anything suspension wise that's why I was wondering what else I'd need to replace as my coworker asked me about replacing my LCA ball joints. And yes, I'll be using the factory LCA's. I also have an entire front end assembly (drum-to-drum) with all the suspension components and steering linkages from a '71 Demon if I need to steal parts. It wouldn't be difficult to brace the LCA's when they come out. I just need to make sure one of my friends has a welder handy. As much as I'd like to weld up and brace the k-frame, I think I'm going to hold off on that till I do an engine swap.
I just went to the garage and measured the pistons with my digital caliper. The reading was kind of iffy because my batteries were dying but all of the pistons were about 36.5mm in diameter (1.43").
I know Dr Diff recommends the 15/16" bore but when I checked on his website a couple days ago, I think he said the MC was out of stock. I don't think I have feets' brake calculator saved to my laptop. I could probably do a quick search for it.
Dr Diff sent me some hoses, brackets, and hardware to install with the lines. I'm just not sure how they go on as it's the first time I've worked with rear discs. I can post pictures of what I have later.
So, story on the wheels... OzHemi's has a wheel "guy" who supplies him outters. I believe, the same guy also took a set of the centers on OzHemi's Torana and decided to replicate and manufacture a cast set of them. I've seen his ad on CL a couple months ago, but he stated I could get any width between 4-13" (or something) for the 18" wheel, any offset, in any bolt pattern for $1650. So, pretty good deal. If he doesn't have the cast centers anymore, OzHemi also has a supplier for forged centers and I'll just have to bite the bullet and get those. Only problem with going with off the shelf wheels is that I think the rears are going to need less of an offset than the fronts since it's an A-body rear and not a B-body. I just measured and it's ~58.5" rotor-to-rotor.
With regarding to tire size, I know it's doable. If it's going to be that difficult to get a 275/35/18 on there, I can go one step down to 265/35/18 (losing some sidewall) or I can probably try to fit a 255/40/18 which may offer a more comfortable ride.
Now, on my Stealth, I do have some aftermarket wheels on them. They're MSW Type 11's. I don't recall completely but I think they were 17x7's or 17x8's with 5.7 bs (45mm or 38 mm offset). I was using 245/45/17 wheels on that. I could probably tell my mechanic to remove one of them and I could try using one as a mach up; however, I'm not sure if they'll fit on the fronts with the big brakes or center register. If they do fit, I could probably just put some new tires on those and hold off on wheels for awhile. http://www.ozracing.com/car_wheels_var/MSW/25190/AVANTGARDE/MSW%2011/25536.aspx#
I'm located in Covina, CA 91724.
Thanks for your help.
[Re: RylisPro]
#1661316
08/20/14 07:50 PM
08/20/14 07:50 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Hope that helps!
I wish I had a lathe handy because I could probably make my own steel spacers if needed be. As for the rod end boots, I already purchased a set and they came in on Monday.
Was the front disc kit supposed to come with a distribution block? If so, I didn't get one. I was holding off on ordering it till I figured out how it works, but I like uhcoog1's idea for just having a T for the front and a line that goes to the back.
[Re: jcc]
#1661317
08/20/14 07:53 PM
08/20/14 07:53 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
To OP, I also use 1350's, but in all honesty, I think they are overkill for non drag use. I suspect though 1330 alternatives are slim, and 1310 not an upgrade from OEM.
I honestly don't know what yoke is on my driveshaft; however, I know for a fact I've got the 7290 on my 8 3/4.
[Re: feets]
#1661318
08/20/14 07:57 PM
08/20/14 07:57 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Well, a weekend project for most people is like a 2-4 week project for me.
I've got at least one friend who has the double flare tool that could probably help me out. And the kit came with rubber lines.
I wish I could bring it out but I don't think work would be too happy with me taking a 1 week vacation with the mess that's going on. Plus I don't have a truck and trailer.
[Re: MuuMuu101]
#1661319
08/20/14 07:57 PM
08/20/14 07:57 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
With getting the right back spacing...you can also get an idea what you think will work, then just have him heat the outer up and drop the center in without welding it. You can try it out and he can move it around as needed until you get it spot on then they can be together. When I had the initial set built for the Torana.. I had a center I bolted onto the car and some slightly oversized (ID diameter) outers that I could slide back and forth and got it just where I wanted it. I have a spare set of wheels here too that I had made with the last of the forged centers, and went with the wider in back and slightly changed the back spacing on too. Just haven't gotten around to the wider tires yet. If you didn't have wheel studs you could hold a wheel of mine under there...with the 265/35-18's on them. (no studs since mine is 5 on 4 3/4" of course )
[Re: OzHemi]
#1661320
08/20/14 08:03 PM
08/20/14 08:03 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Is your wheel guy still making the cast wheels?
And as for your wheel, we could just drill/bore a giant hole through the centers to make the mach up work.
[Re: OzHemi]
#1661323
08/20/14 08:28 PM
08/20/14 08:28 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Oh and if you need driveshaft stuff at all... the place around the corner here is awesome.. Powertrain Industries in GG..
That's who I was planning on using.
[Re: MuuMuu101]
#1661327
08/21/14 01:55 AM
08/21/14 01:55 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
On the wheels I would get 4 fronts and just use thin billet spacers on the rear. The ability to rotate front to back helps a ton on the pocket book.
Mopar to the bone!!!
[Re: MuuMuu101]
#1661329
08/21/14 03:29 AM
08/21/14 03:29 AM
Posts: 2,432 NorCal
RylisPro
NorCal
