Re: Best smallblock head w/stock exaust pattern
[Re: Ian]
#1661142
08/20/14 07:45 PM
08/20/14 07:45 PM
Posts: 614 ont,canada
mopartuner
ont,canada
I was just trying to see whats out there.My current combo runs ok for what it is.I have to make a call on a torque converter and just deciding to change the motor or leave it as is and work with it.I have flowed my heads and they were 268 cfm @ 600 lift.I ported these and they seem (for a home job) they work ok.My combo is a 410 10.5 to 1 (180psi)with a flat tappet solid cam.My car is 3150# w/driver.I have been 123.77 mph with this set up.My best et is 10.95 w/1.53 60 ft.How fast can a car go if it runs 122-123 mph in the quarter?This is pump gas w/mufflers.
410 pump gas solis flat tappet cam 10.95 so far
[Re: mopartuner]
#1661143
08/20/14 07:49 PM
08/20/14 07:49 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Your about there.......... Maybe a little more room
I went about 124 at 10.74 in an old Eddie head flat tappet combo...... 3400 race weight with a 727
[Re: mopartuner]
#1661145
08/20/14 08:05 PM
08/20/14 08:05 PM
B3422W5
Portage,michigan
Yep, at that weight it's very possible to knock a tenth out of that 60 foot. I went 1.44 with what I had, with about a point more compression but good bit more weight. My eddies went 274@ 600 stage two job Hensley did,.... Picking up 60 foot will really help the whole time slip
[Re: mopartuner]
#1661146
08/21/14 09:43 AM
08/21/14 09:43 AM
Posts: 1,178 Indy
FlyFish
Indy
When my Barracuda was on pump gas it ran 10.79 @ 123 with a 1.49-1.47 60' time. This is with a 410, 10.8:1 comp, pump gas, small street roller, through the mufflers, 3250 lbs. You could make nice gains if you can pick up the 60' times about 5 hundredths. I would go to a TNT and try different pump cams and squirters on the carb to get the 60' times down.
For what its worth, my ported eddy's flow 293 @ .600...but my cam is only .550 ish lift. I switched to e85 and the car picked up a CHUNK of ET. Now its in the mid 10's, and should be in the 10.4x's this fall.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: fishy340]
#1661149
08/21/14 04:17 PM
08/21/14 04:17 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
my 360-1 cnc heads, stock and w-2 exhaust patterns
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#1661150
08/21/14 08:06 PM
08/21/14 08:06 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My 360-2 cnc heads are that way also..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1661151
08/21/14 09:36 PM
08/21/14 09:36 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I believe that is because w2 headers had 2 different bolt patterns if I remember correctly if you hold up a standard exhaust gasket the ports don't line up. but its been a while since I was playing with w2s
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1661152
08/21/14 09:42 PM
08/21/14 09:42 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
My ported Eddys flowed just shy of 300 @ .600 on one bench and just over on another.
My best ET is 11.36 @ 118 in a 3400 lb tuck at 7600' DA.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1661154
08/21/14 10:48 PM
08/21/14 10:48 PM
slammedR/T
my ported Edelbrock magnum heads were like 305 cfm on champion racing heads flow bench out of palm coast.
[Re: dusturbd340W5]
#1661156
08/22/14 12:43 AM
08/22/14 12:43 AM
Posts: 300 Willow Spring
dagohman
Willow Spring
I believe you are right It will work ok on a bracket car with cheap gaskets and red high temp rtv I wouldnt do it on a street car.
[Re: fishy340]
#1661159
08/22/14 02:47 AM
08/22/14 02:47 AM
dagohman
Willow Spring
Stock header bolt location yes...But far from a stock exhaust port. J,X or eddie, and pro comp is a stock exhaust port.I wish i could post pictures.
I'm agreeing with you. If he has to retain stock exh. Flange I would not use the Indy heads I don't know which would be best. I've seen several cars run great with the eddies
[Re: dagohman]
#1661161
08/22/14 10:17 AM
08/22/14 10:17 AM
Posts: 162 monticello,ms
andy3965
monticello,ms
Who makes those gaskets with the dual bolt pattern? That set looks like they will work for me. I have econo W2's on my 408 in my d100. So no one makes a W2 header for that combo and I have to use standard headers. Always have trouble with them leaking.
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
