Water Pump Housing 70 440 Bolts, Any Washer's???? #1660731
08/18/14 06:34 PM
08/18/14 06:34 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
As I rack my brain trying to remember tearing the motor down, I seem to remember a washer on the bolt behind the nipple? I also have it in the bag with the bolts, was that correct? Thank you.
Admiration For Multiple Carburetor Vehicles...
Re: Water Pump Housing 70 440 Bolts, Any Washer's???? [Re: Stewpar] #1660732
08/18/14 09:34 PM
08/18/14 09:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
conical washer under every bolt
Re: Water Pump Housing 70 440 Bolts, Any Washer's???? [Re: gtx6970] #1660733
08/18/14 10:42 PM
08/18/14 10:42 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Thanks Bill!
Re: Water Pump Housing 70 440 Bolts, Any Washer's???? [Re: Stewpar] #1660734
08/18/14 11:27 PM
08/18/14 11:27 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
My 440 water pump had only one washer and that was on the bolt behind the nipple. This bolt was also approx. 1/4" longer than the other bolts. I can't say for sure it was originally like this from the factory.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: Water Pump Housing 70 440 Bolts, Any Washer's???? [Re: RealWing] #1660735
08/19/14 12:58 AM
08/19/14 12:58 AM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Here we go, no this is how I remember it???
Re: Water Pump Housing 70 440 Bolts, Any Washer's???? [Re: Stewpar] #1660736
08/19/14 12:56 PM
08/19/14 12:56 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Here we go!!!
The Moparr Motors Chrysler Vehicle Restoration Reference Manual (Guide to B Body fasteners 1968-1970)has a note which says "The bolts in position #3 were consistently found with a washer"
Position #3 is the one behind the nipple.
