Re: Water Pump Housing 70 440 Bolts, Any Washer's????
[Re: Stewpar]
#1660732
08/18/14 09:34 PM
08/18/14 09:34 PM
Posts: 21,405 It's a dry heat
gtx6970
It's a dry heat
As I rack my brain trying to remember tearing the motor down, I seem to remember a washer on the bolt behind the nipple? I also have it in the bag with the bolts, was that correct? Thank you.
conical washer under every bolt
[Re: Stewpar]
#1660734
08/18/14 11:27 PM
08/18/14 11:27 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
My 440 water pump had only one washer and that was on the bolt behind the nipple. This bolt was also approx. 1/4" longer than the other bolts. I can't say for sure it was originally like this from the factory.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: Stewpar]
#1660736
08/19/14 12:56 PM
08/19/14 12:56 PM
RealWing
Ontario, Canada
Here we go!!! The Moparr Motors Chrysler Vehicle Restoration Reference Manual (Guide to B Body fasteners 1968-1970)has a note which says "The bolts in position #3 were consistently found with a washer" Position #3 is the one behind the nipple.
