Neutral safety switch wiring route #166047
12/11/08 11:04 AM
12/11/08 11:04 AM
Sterling Hts, MI
2
2FASTCORONET Offline OP
Sterling Hts, MI
I've got a 66 Coronet with a newer 727 in it. Where or how does the wiring run from the switch in the transmission to the switch at the firewall? Does it run outside the car or does it come in to the interior? Thanks Dennis
Re: Neutral safety switch wiring route [Re: 2FASTCORONET] #166048
12/11/08 11:54 AM
12/11/08 11:54 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It should come up over the top of the trans and join the rest of the wiring on the firewall at the back of the motor.
Re: Neutral safety switch wiring route [Re: 2FASTCORONET] #166049
12/11/08 11:58 AM
12/11/08 11:58 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
On my 70 Cuda the BU light wire plugged into the firewall bulkhead connection and the start ground wire plugged into the starter solonoid at the fenderwell.
Re: Neutral safety switch wiring route [Re: Jim_Lusk] #166050
12/11/08 12:09 PM
12/11/08 12:09 PM
Sterling Hts, MI
2
Sterling Hts, MI
