sliding glass ID help on D150 #1659796
08/16/14 07:30 PM
08/16/14 07:30 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
I took the glass out of a 89 D150 which had sliding rear glass & the thick weather striping and I have another sliding glass that seems alittle different, which one is the factory & which is not? heres some pix
Re: sliding glass ID help on D150 [Re: 98RAM1500] #1659797
08/16/14 07:30 PM
08/16/14 07:30 PM
Crockett ,TX
9
Crockett ,TX
another
Re: sliding glass ID help on D150 [Re: 98RAM1500] #1659798
08/16/14 07:31 PM
08/16/14 07:31 PM
Crockett ,TX
9
Crockett ,TX
heres the weatherstripping
Re: sliding glass ID help on D150 [Re: 98RAM1500] #1659799
08/16/14 08:05 PM
08/16/14 08:05 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
If that tinted (smoked) one is in the glass and not film, it is aftermarket.
I am pretty sure the factory ones were never black (dark) tinted, I think they were all 4 pane, also.
Mine had a factory one in it when I got it, but I took it out and tossed it.
It takes gasoline to interest me.
Re: sliding glass ID help on D150 [Re: VL21] #1659800
08/17/14 12:13 AM
08/17/14 12:13 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
More than one company made them
Re: sliding glass ID help on D150 [Re: 76dodgeboy] #1659801
08/17/14 09:55 AM
08/17/14 09:55 AM
Crockett ,TX
9
Crockett ,TX
well the one that was used with that thick weatherstripping has a square like frame all around the glass, while the other one has a thick frame with a thin lip that's more shaped like a solid back glass all around with it I guess it uses the thin weatherstripping right?
Re: sliding glass ID help on D150 [Re: 98RAM1500] #1659802
08/17/14 08:59 PM
08/17/14 08:59 PM
5thAve Offline
5thAve  Offline
Mine doesn't use that ugly gasket that sticks out like that and the glass has pentastars on it. But it's a 79 so maybe things changed in the 10 years.
One thing that's a dead giveaway for aftermarket silders is the usually the frame doesn't match the shape of the window opening properly.
Re: sliding glass ID help on D150 [Re: 5thAve] #1659803
08/20/14 11:11 PM
08/20/14 11:11 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
I thought that if it was factory glass that it had a pentastar in the corner somewhere?
Moparlee
Re: sliding glass ID help on D150 [Re: Robbins] #1659804
08/21/14 08:33 PM
08/21/14 08:33 PM
Crockett ,TX
9
Crockett ,TX
I found the penastar on one corner which is the one that happen to be busted out by the last owners kids when he had it seems I got 3 after market sliders that use the small weather stripping
