How hot do cast iron exhaust manifolds get? #165913
12/10/08 10:14 PM
12/10/08 10:14 PM
BDW Offline OP
BDW  Offline OP
I painted my 340 stock exhaust manifold with hi-temp paint and it blistered as soon as I fired the motor up?
I wired brushed off all surface rust, hit it with some Ospho, then painted.
What went wrong?
Re: How hot do cast iron exhaust manifolds get? [Re: BDW] #165914
12/10/08 10:38 PM
12/10/08 10:38 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
I measured mine with a laser pyrometer and they usually are in the 460-520* range
Re: How hot do cast iron exhaust manifolds get? [Re: fjr340gts] #165915
12/11/08 07:51 AM
12/11/08 07:51 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
They get hotter than that under load.
Re: How hot do cast iron exhaust manifolds get? [Re: fjr340gts] #165916
12/11/08 07:55 AM
12/11/08 07:55 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I did the same thing and get about 800-850 degrees at idle. I'm sure it goes way up under full throttle. I guess there are spray paints that will stay on but I've given up painting my manifolds. It's kind of like trying to keep the bottom of the car clean. If you drive it it's going to get dirty and natural colored manifolds really don't look bad at all.
Re: How hot do cast iron exhaust manifolds get? [Re: dmerc] #165917
12/11/08 10:28 AM
12/11/08 10:28 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 440 in my '69 r/t varies from 550f at #1 cylinder to 650+f at #7 under very moderate driving conditions.
Re: How hot do cast iron exhaust manifolds get? [Re: lewtot184] #165918
12/11/08 10:37 AM
12/11/08 10:37 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Skip the paint. First you must remove and media blast the manifolds clean,then wipe them down with a liberal coat of clean 90 weight (yes, it's a nasty mess) wipe them off, put them on the engine, and run them until it all smokes off. It stinks to high heaven so be sure to do it away from your place. You can also cook it off prior to assembly with a propane torch, either way works about the same. The raw cast iron will take on a nice mellow brownish gray color and won't rust for ages, a light spot touch up with a wire brush and more 90 weight during the first year will keep rust at bay for many years, the results are pretty amazing.
Re: How hot do cast iron exhaust manifolds get? [Re: ScottSmith_Harms] #165919
12/11/08 12:26 PM
12/11/08 12:26 PM
That is so unconventional that I'm just going to have to try it but 1st I'm going to try some black barbeque grill paint.
Re: How hot do cast iron exhaust manifolds get? [Re: ScottSmith_Harms] #165920
12/11/08 01:03 PM
12/11/08 01:03 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Sounds like the method (sans the 90wt ) to season a cast iron skillet. That should work great.
-Dave
Re: How hot do cast iron exhaust manifolds get? [Re: RapidRobert] #165921
12/11/08 01:56 PM
12/11/08 01:56 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
That is so weird Scott! Wonder if that would work on headers?
I am tired of spraying Plasticoat white on the Hookers.
Isn't there a coating that Eastwood or somebody sells?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: How hot do cast iron exhaust manifolds get? [Re: Rug_Trucker] #165922
12/11/08 03:31 PM
12/11/08 03:31 PM
yeah but I dont know how good it is though
Re: How hot do cast iron exhaust manifolds get? [Re: RapidRobert] #165923
12/11/08 03:48 PM
12/11/08 03:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
In my own experience it works best on cast iron but many other metals as well. I didn't invent the method, Mike at Rcket Restorations showed it to a while back, works great for treating cast iron of all types when you want a more original appearance (as opposed to painted which is never "correct").
Re: How hot do cast iron exhaust manifolds get? [Re: dmerc] #165924
12/11/08 04:07 PM
12/11/08 04:07 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
They get hot enough to cook on.
If you are looking at an original look, leave them natural cast.
Re: How hot do cast iron exhaust manifolds get? [Re: MoparforLife] #165925
12/11/08 05:07 PM
12/11/08 05:07 PM
KS
MoparKansas Offline
MoparKansas  Offline
KS
Calyx (sp? keeps them looking nice, but a little too shiny for stock cast iron. It also will rub off somewhat for a while. My brother has it on his car and hasn't had it bake off yet...
http://www.calyxmanifold.com/
Re: How hot do cast iron exhaust manifolds get? [Re: MoparKansas] #165926
12/11/08 06:21 PM
12/11/08 06:21 PM
BDW Offline OP
BDW  Offline OP
The 90w does sound unconventional! I might just have to try it. I'm still curious what happened with the paint. It started separating as soon I fired the motor up! It actually looked like there was a latex glove on it and was being blown up. For some reason the paint didn't even attempt to bond with the metal.
Really frustrating.
Re: How hot do cast iron exhaust manifolds get? [Re: BDW] #165927
12/11/08 06:31 PM
12/11/08 06:31 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
FWIW I had mine Jet-Hot coated and have looked like this for the past 5+ years now...reduced the underhood temps as well
1MYTGTX
Re: How hot do cast iron exhaust manifolds get? [Re: 1MYTGTX] #165928
12/11/08 06:45 PM
12/11/08 06:45 PM
BDW Offline OP
BDW  Offline OP
Looks nice, where did you have it done & how much did it cost?
Thx
Re: How hot do cast iron exhaust manifolds get? [Re: BDW] #165929
12/11/08 09:14 PM
12/11/08 09:14 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I'd bet it has something to do with the Ospho. Probably hadn't fully cured so you had some moisture trapped under the paint that bubbled once you heated them up.
Re: How hot do cast iron exhaust manifolds get? [Re: rss] #165930
12/11/08 10:35 PM
12/11/08 10:35 PM
BDW Offline OP
BDW  Offline OP
Your probably right, but it might have something to do with cleaning it with easy-off oven cleaner initially. I thought I rinsed it well, but maybe not enough? After letting them dry for a day I then used a wire bush on a drill to clean it up further. I then put on the Ospho. Manifold actually sat then for a week at this point(I had to go out of town on business).
After painting, I set it out in sun for 2 days.
But it must have been some sort of trapped moisture, that paint didn't last 10 seconds!
Re: How hot do cast iron exhaust manifolds get? [Re: BDW] #165931
12/11/08 11:50 PM
12/11/08 11:50 PM
Detroit, Michigan
fjr340gts Offline
fjr340gts  Offline
Detroit, Michigan
I had mine coated. The inside with a thermal barrier, and the outside with a cast iron gray coating.
Cost about $150 for the pair.
www.automotivemachine.net did the process.
Re: How hot do cast iron exhaust manifolds get? [Re: RapidRobert] #165932
12/11/08 11:53 PM
12/11/08 11:53 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
..dont even waste your time.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
