Re: How hot do cast iron exhaust manifolds get? [Re: GoodysGotaCuda] #165933
12/12/08 12:08 AM
12/12/08 12:08 AM
it wont even work with good prep? When I'm flame broiling my steaks it get pretty hot.
Re: How hot do cast iron exhaust manifolds get? [Re: RapidRobert] #165934
12/12/08 12:15 AM
12/12/08 12:15 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
i've prepped the heck out of two sets of headers. Well, short of media blasting, the paint hasn't held up for more than 3-4 months of weekend use.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: How hot do cast iron exhaust manifolds get? [Re: GoodysGotaCuda] #165935
12/12/08 12:19 AM
12/12/08 12:19 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Thermal coating is the best if you want it to last.I have mine done locally.
Re: How hot do cast iron exhaust manifolds get? [Re: GoodysGotaCuda] #165936
12/12/08 01:01 AM
12/12/08 01:01 AM
alright I'm convinced. I will explore another option
Re: How hot do cast iron exhaust manifolds get? [Re: ScottSmith_Harms] #165937
12/12/08 08:21 AM
12/12/08 08:21 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Skip the paint. First you must remove and media blast the manifolds clean,then wipe them down with a liberal coat of clean 90 weight
I agree with Scott's oil treatment except I use ATF instead of 90 Gear oil, the ATF leaves a blueish tan/gray and it last a long time.
Re: How hot do cast iron exhaust manifolds get? [Re: dmerc] #165938
12/13/08 12:42 PM
12/13/08 12:42 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
850 sounds about right for an engine that has been running for awhile
I have not measured more than 1280 F
at short bursts of full throttle
at the hottest cylinder
on a 1995 360,
but I would guess in the worst case
it would approach 1500 F on the inside of the manifolds
and perhaps 1400 on the outside
The black magnetite coating
(like on impact sockets)
that people are trying to make on the outside
using the oil coating will break down at those 1200 to 1400 temperatures
$150 for a thermal barrier inside and another anti-corrosion coating outside sounds like a great bargain to me for a pair of manifolds
Re: How hot do cast iron exhaust manifolds get? [Re: 360view] #165939
12/13/08 01:24 PM
12/13/08 01:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Maybe true but in real world testing I haven't seen it breakdown much at all, as I mentioned a light periodic touch up is all it takes.
Re: How hot do cast iron exhaust manifolds get? [Re: ScottSmith_Harms] #165940
12/13/08 01:38 PM
12/13/08 01:38 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The ATF/oil treatment has been around for a long time. I used it back in the 80s. I don't even bother anymore...lol. No car ever looked that way on the dealer lot. They already had rusty manifolds from running and loading on trains and trucks. They were all a light cream/rust color...lol.
Re: How hot do cast iron exhaust manifolds get? [Re: moper] #165941
12/13/08 01:41 PM
12/13/08 01:41 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
True, but if you prefer to not see rust it's a heck of allot closer to looking original than ANY kind of paint or high temp coating. Oh yea, and it's practically free!
Re: How hot do cast iron exhaust manifolds get? [Re: ScottSmith_Harms] #165942
12/13/08 02:02 PM
12/13/08 02:02 PM
BDW Offline OP
BDW  Offline OP
Scott,
You ever coat them already on the car? I really don't want to pull them off again.
I know you mentioned a light touch up, what about the initial job?
Re: How hot do cast iron exhaust manifolds get? [Re: BDW] #165943
12/13/08 02:18 PM
12/13/08 02:18 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No, won't work well, you need to remove them, blast them, and then coat them if you want good results. Just slopping some on already half baked /rusty manifolds will usually result in a blotchy weird looking finish.
Re: How hot do cast iron exhaust manifolds get? [Re: ScottSmith_Harms] #165944
12/13/08 02:26 PM
12/13/08 02:26 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I was told to try mineral spirits and graphite by a older man at a car show I was attending a few years ago. I bead blasted the manifolds and rubbed it on. It is messy but they have stayed nice looking so far.
