69 RR steering column wiring harness #165668
12/10/08 09:18 PM
12/10/08 09:18 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
Does anyone make a harness for the steerin column on a 69 RR? I have got to have everything that goes in there, it is all gone. Thanks Ronnie
Re: 69 RR steering column wiring harness [Re: okie] #165669
12/10/08 09:42 PM
12/10/08 09:42 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
It sounds like all you need is a full turn signal switch, factory style. The plastic connector is not included but should be the same across all the 60s Mopars.
There are some NOS switches out there. Brad's, Year one, etc
Re: 69 RR steering column wiring harness [Re: sthemi] #165670
12/11/08 08:53 AM
12/11/08 08:53 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I need everything that goes inside, they took everything out, the gear selecter lite, all the turn signal parts all the screws and any thing else that went in there. It is amazing what some people do.
