Idle tuning problem #1656486
08/08/14 05:11 PM
08/08/14 05:11 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
My idle started acting weird recently and I can't figure it out. When I rev it up and drop it to idle, it idles at 1400 for a minute or so and then will drop to 900. I can't get that 500 rpm jump to clear out. I've plugged the vacuum lines, sprayed for vacuum leaks, replaced the throttle plate, removed the power valves, balanced the idle screws, reset the floats and ensured the timing IS NOT increasing at the higher idle. Also replace the plugs and wires and the compression and valve lash are perfect. I'm running a LARGE solid cam and have very low vacuum at idle but it was idling fine before now. Any ideas?
Re: Idle tuning problem [Re: mt162] #1656487
08/08/14 05:23 PM
08/08/14 05:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Two things if the timing is going back to the base
timing... make sure the blades are closing to the right
point and if so blow out the mixture screw holes..
but normally the timing is slow returning to base..
clean and lube the dist weights
Re: Idle tuning problem [Re: MR_P_BODY] #1656488
08/08/14 07:09 PM
08/08/14 07:09 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
The blades are returning to the stops. I also put on a new throttle plate with no change. I also force them back to the stops and it doesn't change the idle any. I put heavy springs on the distributor and checked with a timing light so the timing doesn't' start to increase until past 2k rpm and I've watched the timing while it is at high idle and it is not moving off of base idle setting. The idle screws seem to work but I will try blowing them out.
Re: Idle tuning problem [Re: mt162] #1656489
08/08/14 10:43 PM
08/08/14 10:43 PM
johnmilner Offline
johnmilner  Offline
what carb? what power valve?
Re: Idle tuning problem [Re: johnmilner] #1656490
08/09/14 12:26 AM
08/09/14 12:26 AM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
It's a 4781 850 Holley. I was running a 2.5 power valve but it still does the same thing after I removed it and put in a block-off plug.
Re: Idle tuning problem [Re: mt162] #1656491
08/09/14 02:57 PM
08/09/14 02:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Vacuum advance hooked up?
Re: Idle tuning problem [Re: Dodgem] #1656492
08/09/14 11:15 PM
08/09/14 11:15 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
No vacuum advance.
Re: Idle tuning problem [Re: mt162] #1656493
08/10/14 08:36 AM
08/10/14 08:36 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
What dist because I know the msd with the light spring after awhile the springs loose there tension.
Re: Idle tuning problem [Re: Scamp408] #1656494
08/10/14 10:25 AM
08/10/14 10:25 AM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
I've ruled out timing because I am watching it with a timing light while this is happening and the timing is not moving off of base. When I rev it the timing will come up but drops back down to base right away even though the idle will not drop back down to 900 for a minute or so.
Re: Idle tuning problem [Re: mt162] #1656495
08/10/14 10:31 AM
08/10/14 10:31 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Also, high float levels will cause this
Re: Idle tuning problem [Re: mt162] #1656496
08/10/14 10:41 AM
08/10/14 10:41 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What are the cam and motor specs?
I'm wondering if it needs more initial advance to carry the idle. twist dizzy up 5 to 10 degree to test idle at that spot (not drive) just to see what gives a better idle adjustability.
I use mopar springs in my MSD to give quicker advance and thus more idle advance.
Re: Idle tuning problem [Re: mt162] #1656497
08/10/14 11:41 AM
08/10/14 11:41 AM
johnmilner Offline
johnmilner  Offline
it needs a 6.5 power valve in front.
Re: Idle tuning problem [Re: johnmilner] #1656498
08/10/14 11:46 AM
08/10/14 11:46 AM
johnmilner Offline
johnmilner  Offline
Re: Idle tuning problem [Re: johnmilner] #1656499
08/10/14 11:50 AM
08/10/14 11:50 AM
johnmilner Offline
johnmilner  Offline
a holley carb must run rich, put those 6.5 pv's back in there and square jet it somewhere in the 80 range of jets.
Re: Idle tuning problem [Re: MR_P_BODY] #1656500
08/10/14 06:36 PM
08/10/14 06:36 PM
Indiana
mt162 Offline OP
mt162  Offline OP
Indiana
That may be it. I have them adjusted way down but it seems like they seep out of the holes more than they should. I wrote it off as from engine vibration but now I think maybe the needle and seat may be leaking a little.
Re: Idle tuning problem [Re: mt162] #1656501
08/11/14 02:37 PM
08/11/14 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
A wide band is your friend and can help you through this stuff plus put a bad azz tune on that puppy...........
Re: Idle tuning problem [Re: Thumperdart] #1656502
08/11/14 02:42 PM
08/11/14 02:42 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
distributer gunked up and weights are sticking
Re: Idle tuning problem [Re: sixpackgut] #1656503
08/29/14 12:28 AM
08/29/14 12:28 AM
johnmilner Offline
johnmilner  Offline
any progress?
Re: Idle tuning problem [Re: mt162] #1656504
08/29/14 11:47 AM
08/29/14 11:47 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s because the pv has no influence on idle nor do the jets NORMALLY. Take it off and check t-slot location on the butterflies as it`s set up now, note where they are and report back. Could be lean too.............get a wideband a.s.a.p. and get a feel for the different circuits idle/transition can drive you .
