Re: Synthetic tranny leakage--833 4 speed?
[Re: Pacnorthcuda]
#165622
12/10/08 09:50 PM
12/10/08 09:50 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I would never run synthetic in my box, even if it was free
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: GreenBlurr]
#165629
12/10/08 11:42 PM
12/10/08 11:42 PM
Posts: 4,866 N. of 8mile, S. of heaven
Spike
Go Blue!!
Go Blue!!
Never put synthetic anything into something that was designed for real stuff. A. cause it will inexplicably leak like a sive, and B. cuase the sytnetic does not actually lubricate anything properly.
Man the misinformation here could fill a novel.
Synthetic oils, gear lubes, trans fluids for the most part have better detergent packages than conventional fluids. If your motor, trans, rear end leaks after switching to synthetic fluids, you had a leak before it was just plugged up with all the junk found in conventional lubricants.
Replace the seal. Synthetic lubricants are compatible with the various seal materials and will not cause the seals to shrink, crack or degrade. The lubricants should cause the seals to swell slightly to ensure continued proper sealing.
Now the part about synthetic not be able to lubricate anything properly- where to start....
This could not be any further from the truth. Synthetic lubricants have very good anti wear additives in them to prevent metal to metal contact. They flow better than paraffin based lubricants. They remain stable over a wider temperature range. They have superior film strength.
Here is a
Study of automotive gear lubes.
I'll put the proper synthetic lube in over a conventional lube any time.
[Re: Spike]
#165630
12/11/08 12:16 AM
12/11/08 12:16 AM
Posts: 2,069 Renton, WA
GreenBlurr
super gas
super gas
Renton, WA
Here is a
In my best obi wan kenobi voice: "do not listen to this man. funny colored water is not what you want to fill your libricating cases with."
[Re: RussW]
#165634
12/11/08 02:39 AM
12/11/08 02:39 AM
Posts: 10,233 Someplace you aren't
SomeCarGuy
I have a hard time getting anything but syn into the trans. I run my hose down the shifter hole and into the box. Redline pours right in fast. The dino juice takes FOREVER.
I've never had a problem with gear clash with the Redline stuff. 833 or 435 trans.
I want my fair share
[Re: Moparnut426]
#165635
12/11/08 09:28 AM
12/11/08 09:28 AM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Pluss you shouldnt due to the syncros slipping. I know the old 833 uses the threaded bras stop rings, but if they are slightly warn, and not sharp, they can accually slip on the blocker hub causing poor shifting, and grinding gears.
Use the recomended old gunk.
[Re: Jeremiah]
#165639
12/11/08 11:08 AM
12/11/08 11:08 AM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
I had a similar experience and switched back. No more leaks!
Thanks for the straightforward response! I will look for a GL-4 80-90 or 75-90 dino lube. Leaks suck
