Power Steering is worse than Manual -
#1655843
08/06/14 07:38 PM
08/06/14 07:38 PM
Posts: 1,106 michigan
440whiteboy
michigan
I just bought my 73 Charger 3 weeks ago. Just getting her up and running now.
Any idea how to check if the box or the pump needs replaced?
fluid level is up - leaks out in a couple of days.
Extremely Hard to get wheels to even move 1" - I have a Manual steering car which turns easier than this car!
They only see Stars... when hit by a Mopar!
Re: Power Steering is worse than Manual -
[Re: 440whiteboy]
#1655844
08/06/14 07:56 PM
08/06/14 07:56 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Does it leak out when running or even just while sitting? Few things could be the source of the leak: - hi-pressure or return line (likely) - gear itself is leaking - pump is leaking If you had a burst hose, you would be spewing P/S fluid when the car is running. I would wipe it all really clean and have a helper crank the car on stands while you peak under and around the gear/pump and see where the leak is. The factory power steering for these cars is way over powered by today's standards and it should be very easy to turn the wheel on the car while it runs. A lot of people here actually get modified gears (myself included) to drop the pressure and make the steering firmer! Good luck! EDIT: Get the pump itself from your local parts house. 440source wants $100 for theirs which is a bit steep.
[Re: cjskotni]
#1655845
08/06/14 08:01 PM
08/06/14 08:01 PM
440whiteboy
michigan
she is leaking while sitting -
good idea about using a friend - will do - thanks -
I would probably think the pump is bad -
[Re: 440whiteboy]
#1655846
08/06/14 08:35 PM
08/06/14 08:35 PM
Posts: 3,884 Oregon
hooziewhatsit
Sounds like it needs bled; raise the front end, engine off, rotate the wheel lock to lock a few times, add more fluid. Sometimes need to start the engine for 5 seconds, then go lock-lock. If you're leaking it all out over a few days, you'll need to rebleed each time you refill And yes, the wheel will be very hard to turn if it hasn't been bled.
[Re: RSNOMO]
#1655849
08/07/14 01:23 AM
08/07/14 01:23 AM
Posts: 4,848 Memphis
HemiRick
Memphis
It the pump leaks just sitting its probably bad and not making any pressure while running and this explain hard steering.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1655850
08/07/14 09:31 AM
08/07/14 09:31 AM
440whiteboy
michigan
Thanks for the needed advice - will keep you posted -
[Re: 440whiteboy]
#1655851
08/08/14 10:31 AM
08/08/14 10:31 AM
440whiteboy
michigan
I noticed most fluid is leaking from the seal where the steering shaft goes -
I have jacked the front end up - turned many times lock to lock off and running once.
will try it again today.
[Re: skicker]
#1655853
08/10/14 12:31 AM
08/10/14 12:31 AM
440whiteboy
michigan
I could try brake fluid........ but now a new problem for me. I called O'Reilly's yesterday to order a new ps pump. Mine is a Federal with the lines on the side, mounting screw holes opposite side. Got it today.... new problem with new ps pump is the shaft is smaller in diameter! now my pulley won't fit. My old pump is rebuild-able I think. I have not done that before. Was hoping I could just do an exchange to keep this simple - I checked 440 source they only have Saginaw.
[Re: 440whiteboy]
#1655854
08/10/14 10:14 AM
08/10/14 10:14 AM
cjskotni
North Carolina
I have heard that the Federal pumps are hard to find and not as good as the Saginaw pumps. I think 440source has the necessary brackets, studs, and pump/pulley you could buy from one place and swap over to the Saginaw style. The Saginaw pumps are easy to find. In fact, I ordered mine from O'Reilley's when my pump gave up the ghost. Had it the next day and dropped right in. I hate to tell you to throw money at this but I have heard those Federal pumps can be tricky to track down and this would get rid of that problem and give you a better pump. EDIT: Get the pump itself from your local parts house. 440source wants $100 for theirs which is a bit steep.
[Re: cjskotni]
#1655855
08/10/14 10:41 AM
08/10/14 10:41 AM
440whiteboy
michigan
Agreed - new pump is $65 not a bad idea to swap over - another reason I should have went to the nats
[Re: 440whiteboy]
#1655856
08/10/14 10:53 AM
08/10/14 10:53 AM
440whiteboy
michigan
CJ -
Other than the pump R&R issue...
My OP your reply was correct, the pressure line had a loose fitting on the box.
Which has slowed down the fluid under the car. now the rear seal is loose or bad on the box -
couple questions -
Do I need a spanner wrench to try and tighten the end cap where the steering shaft is of the gear box to slow down the leak?
Is there a rebuild kit to buy- and how difficult would the rebuild be of the box?
special tools needed?
[Re: JohnRR]
#1655858
08/10/14 12:20 PM
08/10/14 12:20 PM
440whiteboy
michigan
I will take your advice to heart JohnRR -!
last thing I want to do is mess things up. --------------------------------------------
with the new pump I have, directions say to vac out the old fluid from the lines and box.
I'm thinking to live with the leak until next year to change out the box ( if she is working now )
I have ordered new lines.
any advice about evac of fluid?
would a brake vac hand tool do it?
[Re: cjskotni]
#1655860
08/10/14 01:32 PM
08/10/14 01:32 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
I would just disconnect the lo pressure line and stick it in a bucket and have somebody crank the car. The pump should pump most of the fluid out.
You can change out the fluid before swapping the pump , get a couple qts of fluid and a helper ... take the fan off so you eliminate the wind and the hazard , put the return line off the box into a bucket , cap the nipple on the pump, and run the engine and keep adding fluid till the old nasty stuff is out with the helper turning the wheels back and forth, fluid is now flushed , change the pump.
The lower seal may/should have 2 seals , one is a dust seal to protect the real seal, you can get them out with a hook , the pitman arm must obviously be removed. Clean all the scale off the shafts all the way off before changing any seals. The upper requires steering column removal.
