Re: '69 426 Hemi pics
[Re: dwayne welder]
#1655830
08/07/14 01:42 PM
08/07/14 01:42 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Hello! I just wondered why the intake is not painted?? Thanks
If you look at the pictures of it on the dyno you'll see that the entire engine is not painted. Smart people don't paint the engine till after it's dyno'd/broke in just in case ...
[Re: jim sciortino]
#1655832
08/07/14 03:03 PM
08/07/14 03:03 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Daryl the owner is having his paint guy spray it...wasn't my choice and I had to hear about it everyday from my Dad. It's just a daily driver believe it or not! It's all stock '69 parts and we used the MP 278 hyd. cam, Manley valves, and Diamond pistons @ 10:1 compression. He wants to drive this thing everywhere and he brought me 90% of the parts so I basicly built it the way he wanted it done. Short dyno video, not of the 6500rpm run as I thought we would make more pulls but after reviewing the data Daryl was happy and wanted to go home: http://youtu.be/sDPp_6P2vC0
Brian Hafliger
[Re: Cab_Burge]
#1655834
08/07/14 04:27 PM
08/07/14 04:27 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Well I did the dyno session 2 days ago. With the weather station and correction factor I don't see why weather would be much concern? I test on Chevron 91 from the pump.... Yes a single change of the back carb's metering rods was all I had to do. I've heard that original Hemi's completely stock (street hemi's) make around 450-460HP. This is FACTORY stock...but I have no data on a FACTORY stock 426... Given that we got 480HP with a better cam but less compression seems correct to me! Daryl was worried about it hitting 425HP It is what it is...
Brian Hafliger
[Re: JohnRR]
#1655837
08/08/14 02:23 AM
08/08/14 02:23 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Hi Brain, hope all is well. What rod/ bolt combo is in that engine that required you to cut the windage tray to make room for the bolts? Is it a stock rod with a nut and bolt?
Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#1655838
08/08/14 02:58 AM
08/08/14 02:58 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Thanks, Troy
Yes stock rods with ARP bolts. They extend past the end of the nut quite a bit!
[Re: Brian Hafliger]
#1655839
08/08/14 11:22 AM
08/08/14 11:22 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Is your tray a stroker tray? I know jegs sells one for the 3.75 stroke & also for a 4.25 stroke. I got the stroker tray for my 383 in case I wanted to build a low deck 470. Here's a pic of the stock tray next to the jegs stroker tray. I also drilled 3/8" holes for better drain back.
[Re: Triggerfish]
#1655840
08/08/14 11:24 AM
08/08/14 11:24 AM
JohnRR
U.S.S.A.
Stroker tray is not really needed for a 3.9 stroke and 2.2 rod ends .
#1655841
08/08/14 02:15 PM
08/08/14 02:15 PM
Posts: 43,249 Bend,OR USA
Cab_Burge
The last time I was in Indio in July or August it was 105 F with around 50 % humidity at 9:00 A.M. and I have no idea of the B.P. I can remember swimming in the local motel swimmimng pool in Blythe at 1:30 A.M. in the morning in the summer when it was still 98 F The weather does matter, trust me, it was 51 F outside my porch at 8:30 A.M. here this morning. Forcast calls for 85 F for the high here today
