Re: Fixed Fans
[Re: PossessedDuster]
#1655440
08/05/14 09:54 PM
08/05/14 09:54 PM
RapidRobert
what is the pump pulley ratio? How many blades on the fan? 6 or 8 vanes on the pump? shroud? fan distance into the shroud? If its locking up when hot I wouldn't think it'd be that (fan clutch)
Re: Fixed Fans
#1655443
08/06/14 03:49 PM
08/06/14 03:49 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Get an IR temperature gun and give us numbers. Is there a 20+ degree temperature drop between the upper hose and lower hose? Are there hot spots on the radiator? The basic symptoms lean towards an inadequate lockup of the fan clutch but it's all speculation until you get facts to work with. Get numbers and get back with us.
Re: Fixed Fans
#1655444
08/06/14 04:28 PM
08/06/14 04:28 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
The jaguar based fan clutch just isn't cutting it in stop and go traffic on the Belvedere with the 440.
Cools fine at speed and the rest of the system is all new/rebuilt so no issues there.
Short of trying the repro one Tony's parts has who here runs a fixed fan? Opinions?
The rad is doing it's work at highway speeds..low speeds would point to the clutch not engaging to spin the fan...or the fan is not positioned in the shroud properly.....last would be a look at the waterpump flow...what temp is "good" at highway speed ?...yours ?
Re: Fixed Fans
[Re: feets]
#1655445
08/06/14 05:42 PM
08/06/14 05:42 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
My built 440 with a never touched 65 C body rad and shroud and stainless flex fan runs 180 or so all day.My kids 62 413 no shroud but recored OE rad runs the same.Even in the 90s it never gets over 190 degrees.Rocky
Chrysler Firepower
Re: Fixed Fans
[Re: Steve Bryant]
#1655449
08/07/14 04:55 PM
08/07/14 04:55 PM
RapidRobert
Steve I would suggest a JY solid steel OE fan with as many blades as you can find & space it ~2/3 into the shroud. You might wanna go to a smaller dia pump pulley to speed up the fan (air) flow and the water flow
Re: Fixed Fans
[Re: BigBlockMopar]
#1655450
08/07/14 05:21 PM
08/07/14 05:21 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I would think that you could adjust the temperature at which the bimetalic spiral locks up the clutch by moving the attachment point of the center of the spiral. Twist the center attachment point forward, or add a spacer that creates more tension in the spiral to lock up at a lower temperaure. To get the fan blades to rotate closer to engine shaft rpm, replace the silicone fluid inside the clutch with a fluid of higher viscosity. Silicone is used because it is fire resistant. Perhaps high viscosity silicone grease could be mixed into the original silicone fluid fill until you got the lesser amount of slip you desire. http://www.amazon.com/Jet-Lube-Silicone-...=silicone+fluidA clutch manufacturer like Hayden might be able to supply you with replacement silicone fluid of various viscosities, rather than a complete new clutch assembly. http://www.haydenauto.com/Hayden%20Custo...rm/Content.aspxhttp://www.haydenauto.com/online%20catalogs-ecatalog/content.aspxA solid 9 blade fan with the right spacer might be the simplest first thing to try.
Re: Fixed Fans
[Re: RapidRobert]
#1655452
08/07/14 10:42 PM
08/07/14 10:42 PM
Posts: 7,664 IN
ahy
IN
Late 70's (eg Cordoba) had a 7 blade fan. A big one. It would need matched with a "heavy duty" fan clutch and would really move the air.
