Re: 426 Hemi smoking issue
[Re: hemi67]
#1653906
08/02/14 03:49 AM
08/02/14 03:49 AM
Posts: 4,796 Castlegar, BC, Canada
That AMC Guy
Check to make sure your PCV is working correctly. If your intake below the carbs is shiny with oil, that'd be the place to start.
My only other thoughts would be to ask what style valve seals do you have? The umbrella style or the positive seal type?
Reason I ask is that I have a similar problem with my AMC V8. After a hard romp, most of the oil is pumped into the heads (AMC's are notorious for poor drainback issues). My top end is old and worn and with half-assed umbrella style valve seals and a rocker area full of oil, lots of oil gets past the seals and into the combustion chamber.
My symptoms were also similar. Good Compression, acceptable leakdown, functional PCV and dry upper intake.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
[Re: hemi67]
#1653907
08/02/14 07:39 AM
08/02/14 07:39 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Yes they are still on the plugs.
On a HEMI you remove the compression washers, as the HEMI well tube is the "washer", chances are you've destroyed the base of the well tube leaving the washer on the plug, so oil is being drawn into the cylinder(s)...don't attempt to "repair"the tubes distorted base, just replace them, all 8, and remove the washer rings from any plugs in the future...common mistake, we've all done it at one time or another
Mike
[Re: DAYCLONA]
#1653910
08/02/14 11:09 AM
08/02/14 11:09 AM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Can you recommend a good source for new tubes?
Master, again and still
[Re: DaveRS23]
#1653911
08/02/14 11:12 AM
08/02/14 11:12 AM
Posts: 18,157 Mass
DAYCLONA
Mass
What year HEMI/cylinder head...and covers used, as there's more than one style of tube(s)
[Re: DAYCLONA]
#1653913
08/02/14 03:50 PM
08/02/14 03:50 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Eddy/MP heads with original 70/71 valve covers. Seems everything Hemi is screwed up right now.
[Re: DaveRS23]
#1653914
08/03/14 12:14 PM
08/03/14 12:14 PM
Posts: 2,505 God's Country Maryland
GODSCOUNTRY340
Try this, use a 12" extension with a spark plug socket installed, clamp in a bench vise vertically with the socket at the top. Put a spark plug, (WITHOUT the washer) in the socket, slide the tube down over this and lightly tap around it to reshape the tube.
[Re: dynorad]
#1653919
08/04/14 02:30 AM
08/04/14 02:30 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
When doing a leakdown check, listen in the intake, exhaust and in the oil fill tube. The hiss will tell you what system is leaking as long as the plug adapter is sealed. I have engines that run a .035 gap on a 5" bore and don't have much loss.....you set the air to 80 PSI and see what it holds at, you can have as much as a 25% loss and still make full power, while some engines lose power with only a 5% loss. I work on airplanes and every year we do a leakdown check so I have lots of experience with this. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: hemi67]
#1653920
08/04/14 03:15 PM
08/04/14 03:15 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
If intake and head ports are slathered with oil coating, almost has to be intake/head geometry seal. Recently went thru almost the same on our six pack 512. New set of Eddy aluminum heads all is well. My issue was severe plug fouling,,a bit different from your problem,,but same idea,,,too much oil in combustion chamber.
Machine shop that set up new heads with bee hive springs, etc. I had check for me the valve guides. They said they and seals were fine.
No more plug fouling. Intake ports are dry,,,had to pull intake again as one of my recently installed Scorpion hydraulic roller lifters decided to take a dump. .25 valve gap on exhaust number 6.
Does it ever end!
