I have a 74 440 "truck" motor cast crank, external balance in one of my toys, so I know flywheel choice is limited, you referenced the large damper, there's 2 basic styles for the 440 cast crank, both are 1 5/8 thick, the 73-75 cast crank has a flat surface where a single timing mark is located, the 76-78 damper has multiple timing marks every 90 degrees plus the timing surface area has a bull nosed taper towards the front, the counter balance ring in front should say "use with 440 cast crank only" they are both basically the same weight...make sure you have the 440 damper and not a 400 damper (1" wide and only ID is a PN#)
I'll assume your currently using the 130 tooth flywheel? if so McLeod PN# 464102 (sometimes ID'd as PN# 464102-17C) it's a steel 30 lbs approx SFI flywheel, it's of the Internal/External design, it is neutral (internal) balance, but is drilled for a bolt on counter weight, you'll need McLeod PN# 564111 counter weight package, 3 weights will be in the kit, but only one will fit the 464102 flywheel, it bolts on the flywheel side facing the engine, the 464102 flywheel has multiple bolt patterns for clutch cover styles and sizes 10", 10.5" and the largest is the 10.95...flywheel and weight kit should run you about $350
Hope this helps
Mike
