anyway to put a 4 bbl aircleaner on a 2bbl carter?
#1653519
07/31/14 03:07 PM
07/31/14 03:07 PM
Posts: 17,861 albany ny
05dakota
albany ny
Re: anyway to put a 4 bbl aircleaner on a 2bbl carter?
[Re: 05dakota]
#1653520
07/31/14 03:09 PM
07/31/14 03:09 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
You could make a ring of wood or relatively stiff metal to adapt the larger opening on the air cleaner to the carb throat... but why on earth would you do that?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: 05dakota]
#1653524
08/01/14 10:55 PM
08/01/14 10:55 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
My experience? Be aware that you most likely will need to extend the threaded rod on the 2bbl. As you know, the 2bbl has a riser that attaches to the carb throat. Typical 4 barrels have the rod thread into the body. When I did mine, I had a threaded extension welded onto the 2bbl piece (I had a spare from a core carb).
Also, over time, due to heat and the force of the wing-nut keeping the air cleaner in place, plus the fact the engine is vibrating the adaptor (I'm talking plastic here) will over time deform and will need to be replaced. Hope this makes sense.
Common sense is a flower that does not grow in everybody's garden
[Re: MoparforLife]
#1653526
08/03/14 12:06 PM
08/03/14 12:06 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
As long as nobody that looks is savy enough to notice the width between heads difference.
The shows that I go to everybody says "Hey. Nice Lincoln."........
Totally.
BTW I was being facetious about the pie tin.
