Re: Starting a 440 car after sitting 19 years. ADVICE.
[Re: floridian]
#1653362
07/31/14 10:49 AM
07/31/14 10:49 AM
RapidRobert
Change oil/filter. fog the cyls. bump dist rotor to #8 plug wire. pull dist/intergear & preoil CCW with the 5/16" hex rod. bump eng 3/4 turn CW further till dampener slit is at TDC. Preoil some more. Open carb & see what you see. hook gas can to pump inlet to avoid tank contamination issues.
[Re: yorker]
#1653363
07/31/14 10:52 AM
07/31/14 10:52 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
remove plugs soak w/ spray lube, change oil, let it sit. Spray some more. Turn over by hand a few times...sprat a little more, turn over. Remove distrib and re-prime the motor, remove fuel line and spray carb cleaner thur it, blow it out all the way to tank, replace fuel filter, drain all gas from tank, (you could just use a gas can if you just want to fire it) spray down carb (be best to remove it and go thru it), put the distrib back in, plugs, wires and fire it up. Watch for mice running out the tail pipes.
[Re: GTX MATT]
#1653365
07/31/14 12:09 PM
07/31/14 12:09 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Oil in the cylinders, fresh oil and filter, fresh plugs, rotor, cap, and points if it has points. Fresh gas. Prime the oil pump and fire it up.
And check the timing chain for slack- with distributor cap off grip both sides of fan belt above crank pulley and rotate in oposite direction of crank rotation while watching for rotor movement. The OEM cam timing gear may still be in there and will fall apart, nylon teeth on aluminum hub.
[Re: Pynzo]
#1653369
07/31/14 06:40 PM
07/31/14 06:40 PM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
5/16" hex rod, about 2' long and good 1/2 drive electric drill to prime. You pull distributor out (leave wires connected, just push cap off to the side. I put a mark on the distributor housing and block to get it in right. Pull the oil pump drive gear. Make sure you note the position of the slot so the distributor tang will line up. Runn drill CCW adn pump should catch prime. I'd check oil. If it looks like it has water or gas in it, change it out with new filter before priming. You can rotate crank by hand (make sure you mark position so it lines up with oil pump gear). This will get oil through the passages in the crank and cam and up to the top end.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1653371
08/01/14 03:18 AM
08/01/14 03:18 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Yep.. this is exactly what I did with my 383 Mag that'd been on a stand for almost 8 yrs before it went into my Sweptline. I pulled the plugs, injected some Marvel Mystery oil & let it sit overnite, then we changed the oil, filter & primed with a drill. Fired right up.
[Re: GTX MATT]
#1653372
08/01/14 12:25 PM
08/01/14 12:25 PM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
If you just want to see if it starts why change out all the points, plugs etc?? YES do this eventually but not at first.. IF it doesn't start THEN start to diagnose....
Why make it hard when it can be easy? They need to be changed anyway, unless you think the plugs and points are good after sitting for 19 years. Why start it to hear it run like sh1t?
Because my thought is if you PUll the dist., install new points, cond, etc, if you mess up ( your out of time for one) and the car doesn't start you have MORE things to do.. If the car starts you know its OK and then you can do a tune up and oil change.. Do I think the car needs this? ABSOLUTELY, but the question as I read it asks " starting it to see if it runs", not starting it and driving it 500 miles.....
Simple is better in this instance
[Re: floridian]
#1653373
08/01/14 12:53 PM
08/01/14 12:53 PM
Posts: 5,166 CT
GTX MATT
CT
Sure you can open up room for error, so I understand that. In the past I've just put the engine at TDC, marked the location of the dizzy against the block and direction of the rotor, and make sure the oil pump drive is slotted parallel with the crank before I took it out and after I put it back in.
I'd at least change plugs first, they can get pretty nasty/corroded sitting for that length of time. But to each their own
[Re: GTX MATT]
#1653374
08/01/14 10:02 PM
08/01/14 10:02 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Lubricating the cylinders with a thin oil or penetrant comes first. That way it can soak while you're doing other stuff.
If you're not going to open up the carb at least pull it off and attack it with brake clean. You can squirt that stuff through all the tiny passages and clean out the varnish.
If you can trust the fuel tank, empty it out and dump in a fresh batch of good stuff. Fresh oil is a cheap insurance policy.
I don't turn the engine until after I get oil pressure. After it holds pressure I'll turn the engine by hand. Lining up TDC is easy with the plugs out. By that time you should be able to roll it with the starter without fear.
Once I know it will hold oil pressure and everything turns freely I'll drop the plugs back in and go for start.
The Imperial sat for ages but it runs fine and doesn't smoke.
