69 valiant bench seat car. Scored a set of bucket seats out of a scion tc and figured while i had the interior out to clean everything, i'd try and slide them in.
The factory mounting location is about 3" higher in the front than the rear which gives the seat quite a tilt in the front. Trying to use those holes had the seat 1 1/2" off center to the left. Moving the seat off the factory mount and center between the tunnel and mount has the seat 2" off center to the right. Passenger side was a no go unless using the factory holes.
How are you guys mounting seats or are you using race seats and mounts? I was thinking i might be able to tweak a set of circle track seat mounts to work but figured i'd see what you guys were using.
http://www.jegs.com/i/JEGS-Performance-Products/555/70225/10002/-1ordered these. Looks like it should work...
